NAS 110 - The Signal Conditioner - Defender Source
Old May 13th, 2014, 05:50 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
Found this under my dash. Has any NAS 110 owner removed this conditioner for an accurate reading?
"The Signal Conditioner: (1993 NAS 110 only)
The engine temperature gauge in your 1993 NAS Defender 110 is not telling you the truth. This is important because most Rover V8s will last a good long time, unless they develop coolant or overheating issues, so you need to know your coolant temperature and keep an eye on it. Behind the dash of every NAS Defender 110 is what is called a "signal conditioner" or "stabilizer." It is Land Rover part #AMR2401."1
1. http://www.eastcoastrover.com/signalconditioner.html
Old May 13th, 2014, 06:46 PM
I did, but I have not run the truck since. I bought a 94 NAS temp gauge to swap in as supposedly that is required too. I need to get the temp sensor too, but that can wait for a while.
Old May 13th, 2014, 07:18 PM
61rover's Avatar
61rover
John Crouse
Many folks just replace with a VDO guage and sender that shows the actual temp.
Old May 13th, 2014, 07:22 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
You can take a temp reading with an infrared temp gauge (i have one). I was going to change unit I checked the temp, mine ended up being fine, this miss temp reading doesn't follow suit with all NAS 110s. Called RN and they basically said check the temp and if its fine leave it.
Old May 13th, 2014, 07:30 PM
So you actually overheated it? As I understand the issue, it reads a normal temp both when normal and when overheating.
Old May 13th, 2014, 07:33 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
No, I read the ECR rover thread and was going to change it over for percautionary measures but decided to use an infrared temp gauge and the temp was fine and coincided with the gage.
Old May 14th, 2014, 12:09 AM
Right, but that is not the problem. The gauge reads fine (correctly) when it is normal temp. It also reads fine when it is overheating. You can't tell because of the conditioner.
Old May 14th, 2014, 09:43 AM
Basically it always says the temp is normal ... Even when it's boiling over, seizing the bores and warping heads.
Of all the things in a v8 defender a lying temp gauge is not what you need.
Old May 14th, 2014, 10:07 AM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
Anyone know why the gauge needs to be swapped out for the system to be accurate? It looks like the wires are just bypassed through the conditioner.
Do you know the VDO part #?
RD - Let me borrow that infrared temp gun to see hwo accurate my gauge is.
Nevertheless even if the current temp gauge equals the actual temp which reads normal, something could go Defender down the road and the temp gauge will "say the temp is normal ... Even when it's boiling over, seizing the bores and warping heads. "...
Old May 14th, 2014, 10:25 AM
I understand the correct gauge to be the 94/95 NAS gauge.
Old May 14th, 2014, 11:47 AM
61rover's Avatar
61rover
John Crouse
All the info on the VDO swap is in here: http://www.defendersource.com/forum/...eferrerid=2895
It's a 20 minute job and you get actual temp instead of "Hot" and "Way too Hot" from the factory setup.
110, nas, nas 110, signal
Wtb: Air Conditioner complete kit for 1999 defender 110 TD5 Crayfish Wanted 3 August 17th, 2013 07:08 PM
Air-conditioner box doesn't drain properly in my 97 NAS rd10014 Series Technical Discussions 1 June 28th, 2013 12:46 PM
NAS 110 temp gauge update to remove signal conditioner evilfij Defender Technical Discussions 50 September 4th, 2010 05:42 PM
Air Conditioner Vents on NAS 110 - How to hold direction of flow? COSteve Defender Technical Discussions 5 July 15th, 2004 11:11 AM
12 VDC Air Conditioner RyanS Defender Technical Discussions 0 May 17th, 2004 04:26 PM
