NAS 110 T support door seal lip - Page 2 - Defender Source
Old January 30th, 2008, 04:07 PM
""cough" bullshit "cough""
They were painted before they went in.
The old ones came out easy because they were rusted, and, as I recall I was able to break the center post off.
I got there about and we (the two of us) worked for about 3 hours (6 man hours total), 2 for the first one and 1 for the second one once we figured out how to get the rivits out without spinning them with the drill.
It was sean roche's 109 (crazyfish on D-90). It was written up in LRM, in fact, there may even be pictures. Maybe three hours is a bit light, but it did not take long. Door allignment I am sure was not up to ECR standards, but it shut well enough. I don't have the body shop book, but I am sure that would give a fair estimate for potential costs. My only point is it is not a "huge DIY job" (ie changing a bulkhead is a huge DIY job). Then we ate dry rub ribs.
It would be a bit more work on a D110 because of the seatbelts (the ones in the corner on the seatbox suck to remove).
Old January 30th, 2008, 10:07 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Ze,
Please post once you determine the correct part numbers for the Euro style supports as this is definately "on the list" of stuff needed.
Matt
Old July 28th, 2008, 08:49 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Originally Posted by R. Kurk
Regarding my earlier reply and question on this thread. The missing piece for the sills, the foam ends, is part AWR3140.
Richard - Are two foam end pieces required for each door? Also, how do the seals attach to the bottom of the door (rivets)? Thanks.
Old July 28th, 2008, 11:27 PM
R. Kurk
Richard Kurk
1993 110 NAS #489
Ryan, I never installed the 'new style' sills. I had already re-furbished the T frame (only moderate rust once the sill plate was removed) and had new stainless (then black powder coated) sill plates fabricated before I received all the parts for the 'new style' setup. I have moved on to other mini-projects, but I plan on returning to install the new style sills ... they seem like the right long term solution. To answer your question on the foam pieces, yes it appears two are needed for each door, one on each end of the new sill (which is shorter than the original). I do not know the OEM method of attaching the sill, but my approach would be to not use rivets, but try something like (emphasize LIKE) the plastic button fasteners on the wheel arch eyebrows which can be easily removed.
Anyone out there (ECR?) know what the best method of attaching the new style sills to the door?
Old July 28th, 2008, 11:58 PM
I used plastic "christmas tree" type fasteners (very small ones) to attach the seals.
110, door, nas, nas 110
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
NAS Defender 110 lrnasd90 For Sale - Vehicles 9 October 29th, 2005 02:01 PM
WTS: NAS 110 AC/heater box headdamage For Sale - Parts 1 October 24th, 2005 08:43 PM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
