NAS 110 Suspension Recomendations - Defender Source
Old January 8th, 2006, 11:44 AM
NAS 110
Kevin Harkins
Hoping some of you may be able to help me with some 110 advice.
I love the stock white steel stamped rims but I'm trying to find them
in 7" x 16". Did Land Rover ever make these (maybe for a 130?) in 7"
x 16"? If so, does anyone know where I can purchase them? I'll go to Wolf rims if I need to...
Can I use 7" x 16" rims with 285/85 16 without lifting the suspension? The "85" is what
concerns me - I know folks running "75".
I need to replace the springs & shocks. I am being recommended the
Rovertym springs & Blistein shocks. Does anyone have a strong opinion about
spring/shock combinations? I'm running with both an ARB bumper & winch so I'm a little heavy up front.
Thanks for your help.
Old January 8th, 2006, 12:26 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I'm running 255/85 X 16s. They are 33" tall. There is a tire height calculator on www.expeditionexchange.com that can tell you what height your 285/85s will be.
I have OME 751s in front, 755s in back. Makes her stand a bit tall in back, but this spring setup is hard to beat when the truck is loaded. A 110 with passengers, off road gear and camping equip can get loaded up pretty damn heavy in the rear. These springs give a 1.5 to 2" lift. I've had mine this way for 3 years and don't need more.
I can go most places except extreme rock crawl. These springs make the truck very tippy on the road. I'm installing a Scorpion HD sway bar with quick disconnects soon.
I've had to trim the front eyebrows a hair to make room for full articulation. This is easily done with a box cutter.
Can't recommend shocks as I've blown out both OME and Koni HTs from overheating with agressive off-road long-distance driving at speed. I think the continuous near full compression over endless whoops is what kills them. My next set will be Koni HT Raids.
Shocks and sway bar are being sourced from www.4X4ag.com.
Doug W.
Old January 8th, 2006, 12:39 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
If I'm not mistaken, NAS 110s all came with those white steel rims. They're known here as NAS 110 Steel Wheels and I believe they call them 130 steel rims in the UK. It's kinda odd that your NAS 110 don't have them, unless of course the previous owner swapped them out. Places like Atlantic British and Rovers North sell them and they are pretty pricey. They do look good though.
As far as suspension, it depends on how you use your truck. Most suspension components are designed for different purposes and it's all a matter of what your purpose is.
Glenn
Old January 8th, 2006, 02:23 PM
roverboy's Avatar
roverboy
Thomas
Booger
Kevin I have a set for sale. I sent you a PM since your email address didn't work. Drop me a line.
tom
"There is absolutely no excuse for the way I'm about to act."
Old January 8th, 2006, 05:27 PM
Jase
Jase
pending
Who makes a 285/85/16? The only thing close that I can think of is Interco's 35/10.5/16 SSR.
Old January 10th, 2006, 08:10 PM
surf110's Avatar
surf110
Ze
130 Project
Doug. I have the same spring set up you have and my D110 is very tippy as well. Do you think the Scorpion HD sway bar would solve this problem? Are installing front or rear? Sorry for the thread hijack.
Old January 10th, 2006, 08:18 PM
Doug's Avatar
Doug
Doug Walker
I think so. I'll let you know after the install. The HD bar goes on the same rear mounts as the original stock sway that I removed some time ago. With the OME lift, spacers are needed on the frame mounts to keep the bar from 'inverting' against the spring mounts -- you can get them from 4X4ag.
Doug W.
Old January 10th, 2006, 08:23 PM
those white wheels are lame IMHO. black natos are the ticket. what wheels are you currently running?
Old January 11th, 2006, 09:32 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I used SR springs & 7100's. The rear is a little stiff but I think will break in I am gonna play with the charge in the shock to fine tune HE HE HE!
Name:	110 resto 004 S.jpg
ID:	4738   Click image for larger version
Name:	110 resto 001sm.jpg
Name:	110 resto 002sm.jpg
Old January 11th, 2006, 10:12 AM
mattarm's Avatar
mattarm
Matt
1993 D110
Peter,
Sent you a PM.
Matt
110, nas, nas 110
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
WTS: NAS 110 AC/heater box headdamage For Sale - Parts 1 October 24th, 2005 08:43 PM
NAS 110 A/C questions rcork Defender Technical Discussions 13 July 19th, 2005 01:16 PM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
