NAS 110 slow to start- help wanted - Defender Source
Old February 3rd, 2009, 10:21 PM
Architect
David Crumley
NAS D90
Help wanted- I have a NAS 110 that is slow to start (some of the time). Sometimes it starts right up. Other times it turns over 8 to 10 times before starting. Starting fluid in the air intake does not make a difference. The fuel pump, rotor and rotor cap, plugs and fuel filter have all been replaced. It seems to struggle starting most when hot. Once it starts it runs great! Any ideas would be appreciated.
Old February 3rd, 2009, 10:55 PM
Grover's Avatar
Grover
Question
Did this happen after you replaced these items? Assuming you still have the 3.9L, these engines are sensitive when it comes to the rotor/cap. What did you replace them with?
Cheers...
Old February 3rd, 2009, 11:26 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Put a Mean Green Starter on that bad boy. It's start fast then!
Mine has one and you can bump roll your way out of a bog!
Dendy
Old February 4th, 2009, 08:46 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
My battery died a few days ago and I had a spare diesel battery around so I put it in my NAS. It is long but skinny and fit under the seat next to the winch solenoid. Man does that thing crank the motor nicely. It was 15 degrees this morning and that puppy fired right up. I had had probelms with cold weather starting in the past, those days are gone now.
As for your problem, hot starting is a common problem, pull your plugs and see what they look like, is it running rich? As stated above, check your dizzy and rotor, is your timing set properly? Many times it is not one thing but a combination of serveral smaller factors.
Old February 4th, 2009, 11:14 PM
Architect
David Crumley
NAS D90
Thanks Grover. I cannot say for sure but it seems like it got worse after the installs. I first changed the fuel filter with an off brand from Rovers North. Then the fuel pump b/c I thought it wasn't getting proper fuel and the black box under the dash indicated the pump had issues. None of this helped. I then replaced the cap, rotor & plugs with a kit from British Atlantic but still no improvement in start time. I did notice that the plastic dust cover under the rotor was cracked (the shield for the elec. ignition).
Still slow to start.
The fuel filter is mounted in the correct direction but, could it be the fuel filter? Perhaps the off brand filter damaged the fuel pump??
Thanks Scott,
The plugs are new and the problem existed with old plugs as well. It might be the timing. Although it runs well once started.
Are there two fuel pumps on a stock NAS 110? My manuals seem to indicate a second pump under the hood?
I will have the timing checked.
Also, what is a "dizzy"?
Old February 5th, 2009, 12:44 AM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
dizzy= electric spinny thingamabob in a gas engine a.k.a. the distributor
Old February 5th, 2009, 08:40 AM
landrovered
S. Smith
I may be stupid but I have never found evidence of a second fuel pump in my NAS, only the unit in the fuel tank.
110, nas, nas 110, start
Wanted: NAS 110 under $30k jessejames4 Wanted 0 December 20th, 2007 10:28 AM
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
90/110 project wanted (NAS or import) mlepisto Wanted 13 June 22nd, 2004 08:56 PM
