My nas 110 is slow to start (about 8-10 revolutions) before firing. I've replaced the following- new fuel pump, plugs, plug wires, dizzy cap & rotor, fuel filter and fuel temp. sensor. The starter is strong and turns it over well. I have to push down on the gas peddle to help it fire off. The new fuel pump runs when I turn the key half way but continues to run non stop. I think myD 90 stops after a brief while. Does anyone have a suggestion on how I can fix this slow starting 110?
Probably a leaky injector or two in my experience.
Turn the key to the position where the fuel pump runs, but the starter does not turn and leave it there for a few seconds before pushing it all the way. If that makes it easier to start, then you are losing pressure in the fuel line and it is likely a leaky injector (could be the check valve/regulator thing).
Next guess would be weak spark from a bad ignition module, silver relay on the way out etc.
Just left the truck. Waiting at half key position doesn't help. Once it starts if I turn it off it will quickly restart. Again that fuel pump just keeps on running at half key. What about the fuel pressure regulator?
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
