Nas 110 roll cage bolts - Defender Source
Old June 24th, 2014, 07:47 AM
jimmybuffett's Avatar
jimmybuffett
Tom
Hell On Wheels....
Trying to locate the 4 bolts that secure the interior feet of the cage through the floor and into the frame , if someone has replaced these and has a source please let me know. Here's a pic of the old ones , thanks Tom
Old June 24th, 2014, 07:53 AM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Tom, did you find a source for all the connecting bolts?
Old June 24th, 2014, 08:07 AM
jimmybuffett
Tom
Hell On Wheels....
Nas 110
I bought a stainless steel kit a while ago , not sure if all the cage bolts are there . I have the old cage bolts but would like to replace. You replace yours ?
Old June 24th, 2014, 08:18 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I would use grade 8 on cage parts try Mc Master or a good hardware store
good luck with your search
Old June 24th, 2014, 08:21 AM
Bolt depot
Stainless look pretty but lack strength of gear 8
Old June 24th, 2014, 09:06 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
http://www.defendersource.com/forum/...highlight=Bolt
Here is an old thread where I was replacing my cage bolts. I bought mine from stig fasteners in the UK. The stainless bolts were A4 strength which seemed to be close to the requirement of the steel bolts safety devices use. He does not normally stock them so you need to call and they are not cheap.
This is a safety issue so I am not representing these as suitable and you should make your own decisions.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old June 24th, 2014, 09:17 AM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
I prefer the Ford part w504775-s424 in black that Jason mentioned. $5 each, anyone here work at Ford?
Old June 24th, 2014, 09:43 AM
You don't want them from Ford, you want to find the Ford part on eBay since they're far less expensive there. That doesn't help Tom on his quest for his bolts though.
Old June 24th, 2014, 09:45 AM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
True, true. Send one to Mc Master and they'll send you however many you need.
Old June 24th, 2014, 10:00 AM
jimmybuffett
Tom
Hell On Wheels....
Thanks - i just tried searching ebay for those Ford parts # , but no luck !
Old June 24th, 2014, 05:07 PM
It's just a 55 or 60mm M10 hex bolt right? Get one anywhere that has a decent selection of bolts.
Old June 24th, 2014, 09:39 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I mean fastenall?
Old June 24th, 2014, 09:54 PM
jimmybuffett
Tom
Hell On Wheels....
I wasn't sure of the size and the strength of the bolts -
Old June 25th, 2014, 02:01 PM
Fastenal, McMaster-Carr, doesn't much matter. Safety Devices supplies stainless for the body mounting points, so the bolts can't be a critical weak point.
A great alternative is Disco rear seatbelt bolts. They're black torx heads like the NAS 110 bolts.
NAS roll cage bolts... bharris Defender Technical Discussions 5 November 5th, 2009 07:29 PM
Blackened, Stainless Roll Cage Bolts! JimC Defender Technical Discussions 40 January 9th, 2008 02:08 PM
(4) T-50 BOLTS - Rear Roll Cage - ST pcscharfe Wanted 9 November 6th, 2007 06:58 PM
Bolts for NAS D110 Roll Cage 61rover Wanted 3 August 13th, 2007 01:27 AM
Roll Cage Bolts Baldewin Wanted 4 January 12th, 2007 01:59 PM
