NAS 110 intertia switch? - Defender Source
Old August 8th, 2008, 10:26 AM
phoenix37's Avatar
phoenix37
john
My fuel pump quit running this morning. Checked the fuse and its good. Where is the intertia switch on this truck? What about the fuel pump relay? Anything else i should check before having to drop the tank? We got alot of rain last night and my passenger seat footwell is soaked if that help.
Old August 8th, 2008, 01:57 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Inertia switch is behind the fuse cover panel (the one right above the tunnel) and on the left side. The fuel pump relay is in the passenger side footwell area on the left side.
Old August 8th, 2008, 02:21 PM
phoenix37's Avatar
phoenix37
john
Thanks Ryan is this in the engine compartment or inside the truck?
Old August 8th, 2008, 02:28 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Both are inside the truck. Remove the fuse panel cover right in front of the gear shifter to access the inertia switch.
Old August 8th, 2008, 04:12 PM
phoenix37's Avatar
phoenix37
john
got it. ok thanks.
replaced the relay. truck fired right up.
Old August 8th, 2008, 09:02 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Good news! Glad you didn't have to drop the tank.
Old August 8th, 2008, 10:15 PM
phoenix37's Avatar
phoenix37
john
That makes two of us. We got 5 inches of rain in 12 hrs! Wouldnt of been much fun to be under the truck in a puddle. This thing is too tall to fit in the garage.
Old August 8th, 2008, 11:34 PM
I keep fuel pump relays with me. I just picked up a RRC, sure nuff the it stopped about a block from home. fuel pump relays fixed. If you owne a Land Rover you should keep fuel pump relays in the glove box.
110, nas, nas 110, switch
NAS 110 AC Switch Stmpede Defender Technical Discussions 8 February 17th, 2009 12:06 AM
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
NAS 110 A/C questions rcork Defender Technical Discussions 13 July 19th, 2005 01:16 PM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
