NAS 110 Handbrake - Defender Source
Old November 17th, 2009, 11:37 PM
rogersta's Avatar
rogersta
Drew Rogers
1993 NAS D110 #51
NAS 110 Handbrake
My handbrake (parking brake) sometimes will not release in my truck and I believe it is the expander (part that is connected to the handbrake cable and pushes and retracts the drums. I called RN and they were quoting me $400 for a new one and $250 for a rebuild kit. Does that sound right? Anyone else dealt with this or have any info on part # and where else I might find one.
Do, or do not, there is no try!
Old November 18th, 2009, 07:28 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I bought one recently from the UK, Paddock I believe . . . around $75
http://www.paddockspares.com/pp/DEFE...Foperated.html
Old November 18th, 2009, 07:52 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
There's very little to go wrong inside them anyway, why not just strip and clean it out?
There's a tapered "plunger" that is pulled when you apply the brake. on these tapers there are 2 rollers that push out the pistons, that then push the shoes out.
I've had numerous ones in the past siezed up, the grease gets all covered in poo and brake dust, and eventually locks solid.
easy to get to:
chock the wheels, handbrake off,
remove the rear prop shaft (you only need to take off the handbrake end, but it may be easier to undo the diff end first then you can rotate and move "up" the shaft to get a socket in there... 9/16"s size)
undo the cross head screw
remove drum (you may need to slacken off the adjuster to get the drum off)
remove the shoes (peel apart and lift off of the lower expander and the top one.... or maybe left and right, depends on what type of brake you have)..make note of where the springs go!
undo the linkage to get the cable off of the expander, then there should be a spring-steel "staple" that just slides off of the back of the expander, it should then pull free.,
clean it up, degrease etc, re-assemble with a little bit of grease in there, re-assemble.
job done!
exploded image<----
Old November 18th, 2009, 12:55 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Yeah, or what he said. They do rebuild very easily. No seals or anything to replace, just a little cleaning, and a little greasing.
Great write-up BTW!!
110, brake, nas, nas 110
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
NAS Defender 110 lrnasd90 For Sale - Vehicles 9 October 29th, 2005 02:01 PM
WTS: NAS 110 AC/heater box headdamage For Sale - Parts 1 October 24th, 2005 08:43 PM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
