NAS 110 fuel light stays on after I fill it with gas. Replace the fuel pump? - Defender Source
Old April 28th, 2014, 06:11 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Question NAS 110 fuel light stays on after I fill it with gas. Replace the fuel pump?
I just changed the damn thing like 4 or 5 years ago (limited driving) and now the fuel warning light stays on even after I fill the tank. The fuel lever sensor works fine, so does the pump, primes and runs great but the light stays on. Does it sound like I need to replace the pump again? sigh... Thanks for any help.
Robert Deniro
Old April 28th, 2014, 06:37 PM
There is a "low fuel unit", a little box of tricks that sets off the light based on the fuel level sensor. So if the gauge is working the problem is not at the tank end. Maybe a bad connection. You need to find the little box. Do you have a manual? Probably a loose connection as low fuel = high resistance.
Old April 28th, 2014, 06:42 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
I had to replace the fuel sending unit on my wife's 1960 MGA and it was all about the ground connection. Maybe that's applicable here?
Old April 28th, 2014, 06:48 PM
If you look in the NAS110 workshop manual, there is a wiring diagram. Section 86, page 71.
Old April 28th, 2014, 06:50 PM
http://www.defendersource.com/forum/...7&d=1233336062
Old April 28th, 2014, 07:10 PM
Neil McCauley
Neil McCauley
Originally Posted by Red90 View Post
I'll take a look, man you have all the links bro thanks!!
------ Follow up post added April 28th, 2014 04:12 PM ------
Thanks, but now the question is, where is that unit box? Behind the dash binnacle?
Robert Deniro
Old April 28th, 2014, 08:26 PM
I think it should be. Look at the diagram and follow the wire from the warning light. It Gould go to the box.
Old April 28th, 2014, 08:53 PM
Neil McCauley
Neil McCauley
ok, thanks for the help I really appreciate it.
Robert Deniro
110, ac, fuel, gas, ht, nas, nas 110
D90 Fuel pump stays on jackaaaps Defender Technical Discussions 0 January 23rd, 2014 09:46 PM
Need to replace fuel fill line 97-D90-736 Defender Technical Discussions 0 May 26th, 2009 01:03 PM
Softtop stays D90user For Sale - Parts 3 January 30th, 2007 04:20 PM
fill that tank with water not GAS!! steved90 Misc. Chit-Chat 13 May 22nd, 2006 12:04 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
