NAS 110 Fuel Gauge Problem Solved - Defender Source
Old March 23rd, 2014, 12:32 AM
3rovers's Avatar
3rovers
Dennis Yard
1993 NAS D-110 #55
I recently had the fuel pump replaced in my 110 and when I got the truck back from the shop, the fuel gauge was reading 1/4 to 1/3 too low. When the tank was full, it was reading under 3/4 tank.
So I inspected the fuel level sensor wiring and its two connectors mating up to the chassis harness. This did not reveal any issues nor correct the problem. I then moved on to the fuel harness grounds, which are bundled with others and bolted to the left rear body, behind the speaker enclosure. It is a straight blade machine screw with a 8 mm nut on the underside.
I loosened up the bolt, brushed the terminals and body with a wire brush and tightened it all up again. The gauge now reads correctly.
See the Oct 1993 NAS 90/110 Workshop Manual Part 5 Section 86 Pages 25 and 39 for Chassis harness data and drawing. See Section 86 Page 71 for the Fuel Tank Level Indicator circuit diagram.
Dennis Yard
Land Rover Club of San Diego
1993 NAS D-110 #55 (GNUTRUK)
2004 Disco II (DSCO DOG)
Old September 8th, 2014, 06:22 PM
COSteve
Steven Reed
93 Defender 110 - #107
Same issue on my NAS 110.
Had to remove jump seat to get to the speaker, bolt is stainless.
was surprised at the amount of corrosion (galvanic ?) between the steel and aluminum.
Cleaned up, reassembled and shot with battery protector and spray paint.
Gauge increased its reading level from 3/4 to past full (fuel tank just filled).
With these trucks at 22 years old and with the different metals in play, that other grounds should be inspected? (Hopefully a bit easier to access)
COSteve
Old September 9th, 2014, 11:29 AM
def11's Avatar
def11
Jason
93 110 NAS
Oh perfect. I have a similar issue as it never reaches full and sometimes bounces way down to between empty and half even though its got 7 or 8 gallons in it. This will help me chase it down and fix.
J
Old September 9th, 2014, 11:58 PM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
Thanks for the lead!! I've been battling the fuel gauge issue since I got the 110. I had noticed on a few occasions, with the truck running and the headlights off, the left rear side marker light would be very dimly lit. I tackled the mess of wires where the speaker once was....and traced the ground from the marker light, as well as the sender and fuel pump...looks like they all tied together...cleaned them all up and so far it is working! Also, the side marker light is off, as it should be, when the lights are off.
Thanks again!
110, fuel, nas, nas 110
Fuel Gauge Problem ollieskins Defender Technical Discussions 4 December 24th, 2010 02:56 PM
Brake light Electrical Problems solved Campbell Defender Technical Discussions 1 February 26th, 2010 10:41 AM
exhaust fumes inside cab! problem solved. johnpiero Defender Technical Discussions 42 July 15th, 2009 08:26 AM
Window Rattle Solved Raider Defender Technical Discussions 1 March 30th, 2007 02:06 PM
Turn signal--problem solved Davis Defender Technical Discussions 0 July 18th, 2004 08:13 PM
