Model: 1993 NAS 110
Symptoms:
1. Driver's turn signal: engine off, ignition on, works properly. Start engine, blinks on the red brake light in the rear, very quickly.
2. Fuel gauge: ignition on, records properly. Start engine, needle immediately goes past E.
3. Brake / Stalling: Engine off, ignition on, brake lights work when pedal depressed properly. Engine on, press pedal, engine stalls. Remove connection behind brake booster from switch to wiring for rear brake lights, press pedal, engine does not stall suggesting it is not a vacuum leak but electrical.
4. Reserve / Lights On / Stalling: Lights on, clutch in, shift to reverse (LT77), and engine stalls. Lights off, shift to reverse, no stall.
5. Power loss / Lights or Signal on: driving, turn lights on, noticeable decline in power. Active driver's turn signal, driving, noticeable loss of power.
Symptoms:
