NAS 110 dashboard panel - Defender Source
Old March 9th, 2014, 09:31 AM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
I need to get behind this to reconnect a new heater cable from the back of the lever to the top of the HVAC box (should I go behind the panel or take off the dash pad).
(Panel) For those who have experience in this, can you please let me know where the screw are to pop this this panel off (I only see the two on the side all the way on the right hand side). I was told there are screws inside the vents, I shined light in there and couldn't find anything.
I was told you don't need to take off the upper dashboard pad and that there are NO clips holding it in place but have received conflicting advise.
i couldn't find a search on this, any color here would be greatly appreciated.
Old March 9th, 2014, 10:18 AM
Originally Posted by rd10014 View Post
I need to get behind this to reconnect a new heater cable from the back of the lever to the top of the HVAC box (should I go behind the panel or take off the dash pad). (Panel) For those who have experience in this, can you please let me know where the screw are to pop this this panel off (I only see the two on the side all the way on the right hand side). I was told there are screws inside the vents, I shined light in there and couldn't find anything. I was told you don't need to take off the upper dashboard pad and that there are NO clips holding it in place but have received conflicting advise. i couldn't find a search on this, any color here would be greatly appreciated.
Can it be replaced by removing the instrument binnacle ... That's much easier and not made of unobtanium ...
Old March 9th, 2014, 10:28 AM
I have done three or four. There are screws behind the vents. I don't recall how many, but never do I recall being "why is this not coming off" so it must be fairly obvious. I always took off the dash top so I don't know if you can do it without it.
Old March 9th, 2014, 11:16 AM
madcowdungbeetle
Carter
I also seem to remember there being one lone screw on the left side where the instrument cluster butts up to it.
Old March 9th, 2014, 11:26 AM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Very helpful, It seems that there's only a few screws and the dash pad can stay in place. If anyone has any additional insight it would be greatly appreciated.
Old March 9th, 2014, 03:14 PM
61rover's Avatar
61rover
John Crouse
There's a really good how-to write up here:
http://www.defenderhelp.com/02-dash.html
Old March 9th, 2014, 04:26 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
This is it, thanks.
110, dashboard, nas, dash, nas 110
FS: NOS NAS ST RH door/capping/interior panel - ALR8104 kiphartzell For Sale - Parts 9 August 8th, 2013 11:25 AM
NAS 110 front speaker and grill, NAS 110 front grill panel (stick out type) evilfij Wanted 2 March 27th, 2007 10:59 AM
NAS 110 Heater/AC Combo Blower COSteve Wanted 2 July 27th, 2005 02:50 PM
Air Conditioner Vents on NAS 110 - How to hold direction of flow? COSteve Defender Technical Discussions 5 July 15th, 2004 11:11 AM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
