NAS 110 AC Removal Questions - Defender Source
Old January 3rd, 2011, 06:44 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I need to remove the A/C from my 110 as part of my restoration as my bulkhead is toast. Is there anything I need to know/do so as not to do any damage, or do I just start disconnecting stuff. Would prefer to keep in as few pieces as possible. I dont know what the issues are around freon or discharging the system. Although I rarely ran it, the A/C did blow cold. AC had been converted to R134 by PO. I plan to reinstall on the rebuild side of my project. Any pointers/advice would be appreciated.
Matt
Old January 3rd, 2011, 10:35 PM
You _should_ have the system evacuated, but you might make a mistake and loosen a fitting and let it sit overnight. An HVAC guy might not touch it if it had one of thoes quickie 134a kits installed since it could still be contaminated with old refrigerant.
If you intend to reuse the system, be extra careful pulling the HVAC box off the bulkhead. Its gonna have tons of horrible sealant mixed with deteriorated foam on there and there are screws buried under all that. You'll shatter the housing if you just pull. Take your time, find all the screws, and use a putty knife as mich as necessary to gently get the thing off.
110, ac, nas, nas 110
NAS 110 ac question Tyler Wirken Defender Technical Discussions 1 June 29th, 2010 11:56 AM
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
NAS 110 A/C questions rcork Defender Technical Discussions 13 July 19th, 2005 01:16 PM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
