NAS 110 A/C Question - Defender Source
Old September 16th, 2009, 08:34 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
My 110 has an issue with the A/C, when I set it to come out of the dash vents it blows through the defrost and will occasionally switch to the vents and then back again to the defrost. It seems like there is a vacuum actuated switch that is not operating correctly. Any help would be appreciated.
Old September 16th, 2009, 10:31 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Gremlins in your system, playing with your nerves .
- Charles Eames
Old September 17th, 2009, 12:01 AM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
I could be wrong but Mike from ECR made a comment about this on another thread.
Old September 17th, 2009, 09:20 AM
landrovered
S. Smith
Calling Mike to the white courtesy phone, Mike...
Old September 17th, 2009, 10:22 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Its a vac issue.
Either the vac motor that moves the flap went tits up, or you have a leak in the vac. system (meaning not enough vac. to hold the flaps open against the airflow).
The most common one I see is some cracking on the vac lines that lead to the vac. reservoir on the LH inner fender (that round black ball with 2 hoses on it). In some cases you can replace those hoses (or just cut off the cracked parts) and then the system will work. That is the only "easy fix".
Email:
Old September 17th, 2009, 10:32 AM
landrovered
S. Smith
Thanks, I assumed it was a vac issue and just wanted to get a bead on where to start before digging into the mysteries of the one off A/C of the NAS. Got to love short run manufacturing. What I don't understand was when LR finally got the A/C right on the NAS 110, why did they go back to the shin busters from then on for everything else?
Since it was working and then went intermittent, I am hoping for an easy solution. We will see.
Old September 17th, 2009, 12:59 PM
bjf's Avatar
bjf
barry f
94 ST #395
I had the same issue and I replaced the broken line with a BMW vaccuum line. Thicker and more flexible. On another note why is it some times when I put the air on high all the dash vents slam shut. WTF
Old September 17th, 2009, 01:17 PM
landrovered
S. Smith
Because they rotate too freely in the housing. If the angle is anything other than level, the airfoil provides lift and they fly shut.
Old September 17th, 2009, 01:59 PM
bjf's Avatar
bjf
barry f
94 ST #395
lame
Old September 17th, 2009, 02:01 PM
landrovered
S. Smith
I was not pulling your pud, the vents are too free in the housing, if there was a bit more resistance, the problem would not happen.
110, nas, nas 110
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
NAS 110 A/C System newfD90 Misc. Chit-Chat 18 September 2nd, 2006 12:21 PM
NAS 110 A/C questions rcork Defender Technical Discussions 13 July 19th, 2005 01:16 PM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
