NAS 110 A/C Heater Mixer Vacuum Hose - Defender Source
Old March 30th, 2016, 03:41 PM
3rovers's Avatar
3rovers
Dennis Yard
1993 NAS D-110 #55
Has anyone removed and replaced the hard yellow plastic vacuum line from the A/C & Heater box in the engine bay, through the bulkhead, to the heat/cool mixer control? I need some tips on the topic before any work is started. The line has hardened and broken off on the engine bay side. It appears to be a very big job to replace.
I was able to order some generic silicone vacuum hose with 2 mm ID and 4 mm ID which seems to replace the size needed.
Also is there a diagram which shows this line and its routing to behind the dashboard? There is none in the repair manual.
Dennis Yard
Land Rover Club of San Diego
1993 NAS D-110 #55 (GNUTRUK)
2004 Disco II (DSCO DOG)
Old April 2nd, 2016, 12:06 PM
3rovers's Avatar
3rovers
Dennis Yard
1993 NAS D-110 #55
Bump
Dennis Yard
Old April 2nd, 2016, 12:27 PM
drsmiley's Avatar
drsmiley
Roger
97 ST
Smile
Hi Dennis
Try Bob Smith at California Auto Haus in Encinitas
Old April 4th, 2016, 10:44 AM
3rovers's Avatar
3rovers
Dennis Yard
1993 NAS D-110 #55
Thanks. Will give him a call.
BTW, check out the LRCSD Facebook page for our next trip to Death Valley in a couple weeks.
Dennis Yard
Old April 4th, 2016, 11:18 AM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
Its just a regular vacuum line so whatever you get just re-route. You can remove the grey front fascia on the dash and you can route the line behind there where the current line is run. That gray piece comes out by first removing the air vents and then removing the screws behind some of them that hold that piece to the dash. You should also loosen the binnacle and remove the end cap on the PS.
Alternatively - you can try to just remove the dash cover but i don't recall if there would be enough room to get to the air/vent control assemble to detach and re-attach that line.
AndrewT
'93 NAS D110 #437
110, ac, heater, nas, nas 110, vacuum
Vacuum hose Lindy Defender Technical Discussions 0 December 22nd, 2011 03:51 PM
Vacuum Hose Replacement tdn Defender Technical Discussions 1 March 5th, 2011 04:00 PM
Source for Silicone Vacuum Hose/Tubing? MUDSUX Defender Technical Discussions 9 May 28th, 2010 10:34 PM
Heater-AC Vacuum Harness Diagram 1993 110 NAS R. Kurk Defender Technical Discussions 17 July 14th, 2009 05:04 PM
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
