NAS 110 A/C Compressor Knocking - Defender Source
Old September 18th, 2013, 09:01 PM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
Coming home on a 2 hour trip from Dallas in 100+ degree Texas heat, my A/C compressor started knocking... Made the trip home, cooking with the windows down, and now trying to figure out my next step. I've talked to one shop that says everything needs to be replaced...compressor, dryers, condensers......and even stuff on the aftermarket rear auxiliary unit (I cannot find any info on that unit)...and lines flushed, etc. The rear unit is tied into the same compressor.
So I guess just putting in a new/used/rebuilt compressor is not recommended without changing and flushing everything out?
I have seen (online) the RN kit that mounts under the dash. Would that work off of my factory dash controls and the dash vents then just be used for heating? Doesn't it take up quite a bit of leg room...and is this a DIY kit?
Anyone needing to get rid of a '93 NAS 110 A/C compressor/system?
Old September 19th, 2013, 12:16 AM
I am planning on running a NAS D90 heater through the stock dash vents on a NAS 110. I would be happy is something worked on it so I had heat. The rest is gravy.
If you are ditching the NAS 110 AC and running the under dash, I would also ditch the big combined AC/heater box for a heater box.
I have a used NAS 110 compressor and I think I have a condensor.
Old September 19th, 2013, 08:26 AM
Likely complete BS ... Sounds like you'll just need a compressor rebuild ... I had mine done by a shop in FL .... took less than a week to turn it round and cost $176.50 . I would also replace the drier at the same time ... but that was only about $30 more.
Air Parts,Inc.
1133 N. Magnolia Avenue
Ocala Fl 34475
352-732-0720 talk to Jon
110, ac, compressor, nas, nas 110
nas 110 a/c blowing hot lordhelemt Defender Technical Discussions 25 July 1st, 2013 07:58 PM
Fabricating an evaporator case for '93 NAS 110 V8 A/C coffee Defender Technical Discussions 7 June 21st, 2013 10:07 PM
NAS 110 Brake Valve? tomaco1 Defender Technical Discussions 0 February 5th, 2011 09:51 AM
NAS 110 remains FS ECR For Sale - Parts 30 October 17th, 2009 09:49 PM
NAS 110 Rolling Chassis and HCPU body parts surf110 For Sale - Parts 5 September 8th, 2009 01:51 PM
