nas 110 a/c blowing hot - Page 2 - Defender Source
Old June 12th, 2013, 10:33 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Originally Posted by ssi19 View Post
Sorry to hijack the thread but I have a related question. Mine blow cold for ten minutes then gradually starts to warm. Even when idling. Any ideas what this could be?
If you get bored and venture out to north Jersey, I can take a look. Hook up gauges and see what's going on. Pm me if interested, I am about 8 miles from GWB
Old June 12th, 2013, 10:30 PM
ssi19's Avatar
ssi19
scott
1995/D90
Wow thanks TJ. If I can peel away from the kids I'll take u up. Ps. I have a D90. Not sure if that matters. Take care.
Old June 12th, 2013, 10:36 PM
Sounds like the heater is heating up once the engine gets warm. Make sure the heater valve is closed. You can see if the heater hoses are hot.
Old June 12th, 2013, 10:41 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The causes for your issue could be too little freon or the system is overcharged or the expansion valve is bad. The average system has both a high and low compressor cut out. You will know if you are undercharged by seeing bubbles in the sight glass of the receiver dryer. You won't see them if you are overcharged, but a high side gauge will indicate too much pressure by overcharging or by the bad expansion valve.
The most common problem is loss of freon and being undercharged as a result, but John will know when he connects the gauges.
RDavisinVA
Old June 27th, 2013, 02:13 PM
ssi19's Avatar
ssi19
scott
1995/D90
Quick update. I don't think it an ac problem. Because when I flip on the ac after driving for a while (first time turning on the ac) it only blows hot. So that would rule out the theory that the ac fails after it runs for a while. Also the heater hoses are hot even when idling. So my heat vents/flaps must be slightly open. Anyone disagree with the logic?
Old July 1st, 2013, 07:58 PM
ssi19's Avatar
ssi19
scott
1995/D90
OK sounds like I am correct. Now on to figuring out how to close this heat vent! Will play with the cable tensions to start....
NAS 110 Transfer Case $450 bitz The Flea Market 0 February 16th, 2011 12:27 PM
NAS 110 Brake Valve? tomaco1 Defender Technical Discussions 0 February 5th, 2011 09:51 AM
NAS 110 remains FS ECR For Sale - Parts 30 October 17th, 2009 09:49 PM
A/C Help......hot, hot, hot! boulderbear Defender Technical Discussions 7 August 26th, 2006 07:54 PM
