NAPA Thermostat in 95 D90 - Defender Source
Old August 16th, 2014, 08:39 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Anyone have experience with NAPA thermostat in their D90? I read an early post that a rover tech preferred the thermostats from NAPA over the oem ones. The stat at my local NAPA is a 190F...part #1542001..made by Vernet. Only negative I see is that it's $21.49. Have time this weekend and don't feel like waiting on ordering from the usual. Just don't want to screw anything up if it's a POS. Thanks
Old August 16th, 2014, 09:48 AM
Just get the ones that fail open and you'll be good. You can always test it in a pan of hot water to make sure it works prior to install.
Viscous Fan Clutch NAPA part # Campbell Defender Technical Discussions 4 January 29th, 2011 09:53 AM
NAPA Power Steering Pump chris snell Defender Technical Discussions 2 January 13th, 2011 03:01 PM
Is this the correct stepper motor from Napa for '97 D90? wicks Defender Technical Discussions 5 September 17th, 2010 04:02 PM
$30 Block Heaters at NAPA themaxx Misc. Chit-Chat 3 November 14th, 2007 04:24 PM
Installing a Napa Stepper Motor p# 2-1738 Heath Defender Technical Discussions 0 January 13th, 2005 10:04 AM
