Name this part + fuse panel question - Defender Source
Old March 7th, 2010, 10:32 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Can someone name this part? It is behind the center section between the air vents. I took the cover off for the iron goat dash kit and was curious....
Also, can I just unscrew each side of the fuse panel aray to run wires up to the new dash kit? What is the best way to do this?
Thanks, Nick
Old March 8th, 2010, 09:43 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Thanks, Nick
It is the multi-function computer that does things like dim your interior lights, bong when you leave the key in, and run the delay on your rear wiper. Its only found on the 97 90s. Not 94-95s.
Yes, it can be tight but you can snake wires up behind the dash that way.
Email:
Old March 8th, 2010, 10:28 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Use a coat hanger or similar to run pull wires up. Do it carefully/slowly and make sure you don't have any edges on the hanger that will snag or rub.
Old March 8th, 2010, 10:30 AM
97-D90-736
Nick Vogel
Thanks for the info. If I dont want the death con 2 chime or the the dimmer, can I leave it out?
Old March 8th, 2010, 11:32 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Ecu
Pretty sure this also controls your rear wiper & washer. Also might control Defog.
R
Old March 8th, 2010, 01:45 PM
97-D90-736
Nick Vogel
Its a ST so I dont have to worry about that.
part
SW Interior Door Panel Question mgrgpg Defender Technical Discussions 8 July 24th, 2007 11:00 AM
fuse panel question Overlander Defender Technical Discussions 3 January 2nd, 2007 01:34 PM
Part # Question - Trim Piece fleabus Defender Technical Discussions 6 July 5th, 2005 02:45 PM
94 ST Fuse Panel Cover mfreeman17 Wanted 0 June 28th, 2004 01:30 AM
