Name that tune?! - Defender Source
Old April 12th, 2016, 05:33 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Name that tune?!
I've been experiencing a strange chattering noise from somewhere in the drivetrain i believe. It sounds like sounds like a bunch of birds or something. I took video from underneath to help you diagnose. thanks.
Old April 12th, 2016, 05:40 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Why don't you get the prop shaft rebuilt, the balance weight hanging on for dear life is't helping things. When was the uj's and centre spline last greased?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 12th, 2016, 06:38 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Honestly I have no idea how old the uj's are. They sure don't look new.
Old April 12th, 2016, 06:51 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
On a stock D90 with no height mod's the front prop shaft is still pretty tilted & will wear the prop joints faster than the rear. 175K+ on my rears & they're still in good shape, the front'shave been replaced about 4 years ago. I'd start there and use Neapco brand joints, they're USA made.
Old April 12th, 2016, 08:12 PM
I agree, it sounds like the u-joints are dry. It's easy to check. Chock the wheels and disengage the hand brake, and get under there and yank on the ends of the driveshaft in every direction you can. If the u-joints are bad it will be fairly obvious since you'll see the joints move (they shouldn't)
Originally Posted by pendy
I'm here for the D's
Old April 12th, 2016, 08:35 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Thanks for the responses, keep them coming. Dumb question, are all of the u-joints the same size?
TUNE UP KIT&ALLOY LUGS WANTED 83 110 mountainviewrover Wanted 4 April 6th, 2008 12:44 PM
Re-tune ecu without catalytic converters Help! bstraw Defender Technical Discussions 0 December 23rd, 2006 10:48 AM
tune resistors and cats vesparover Defender Technical Discussions 3 March 13th, 2006 10:34 PM
"tune resistors" boxerhips Defender Technical Discussions 3 January 17th, 2006 07:10 AM
NAS spec D90 tune resistor help required UKlandyandy Defender Technical Discussions 8 May 7th, 2005 07:05 AM
