name that part (ignition?) - Defender Source
Old July 28th, 2008, 07:12 PM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
whats the nomenclature for this part? Part number?
Thanks.
...you'll feel better in a couple of days.
Old July 28th, 2008, 11:49 PM
R. Kurk
Richard Kurk
1993 110 NAS #489
It appears (90% confidence) to be the ignition amplifier that has been relocated from the side of the distributor. I relocated mine to prevent the recurring failure (every 15k miles based on the service history from the prior owner) of the amplifier when attached to the distrbutor. Moving it away from the engine heat seems to solve the early failure problem. I do not know the kit (it comes as a kit) part number, my local private Land Rover shop purchased and installed it on my 110. You might do a search on the forum to get the part number.
part
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
