Mystery Switch - Defender Source
Old August 30th, 2013, 10:28 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Mystery Switch
Before I start digging behind this switch to see where the wires lead me, anyone know what it was likely used for? I know it's not stock. It has two turn knobs and an LED above. The larger/outer turn knob has 3 positions; left, middle, right. The smaller/inner turn knob turns smoothly, left to right like a volume knob on a CB or radio. It's the only switch I have that doesn't work and it's bugging me. The green switch to the left of it controls the Hella's, the red switch above controls the heated windshield. And the far left switch is the dash light dimmer.
Thanks in advance.
Keith
'95 RRC LWB Aspen Silver
'86 110 SW Conniston Green - SOLD
'95 D90 ST Beluga Black - SOLD
'96 D1 SE7 Willow Green - SOLD
Old August 30th, 2013, 10:31 PM
I was going to guess CB.
Old August 30th, 2013, 11:07 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
The CB has its own controls.
Old August 30th, 2013, 11:12 PM
Regular volume and sub? Who knows?
Old August 30th, 2013, 11:34 PM
its the fluid drip adjuster ... you can set the frequency and type of drips ... everything from engine oil to brake fluid and if you hit the rear bias you can leak gas!
Old August 31st, 2013, 04:51 AM
Flux capacitor.
( also known as dumb ass prior owner crap. Ditto the green thing next to it. Fix properly
Old August 31st, 2013, 08:31 AM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Originally Posted by Rocky View Post
Flux capacitor.
What's wrong with the green switch next to it? It controls the fog lights and works fine.
Old August 31st, 2013, 08:35 AM
You need the proper fog light switch in order for us to accept you into the NYC boost crew. Like mine.
Old August 31st, 2013, 08:49 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
If you don't use the correct rover switches your truck wont break down as often as it should. Duh.
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Boosts suck...
------ Follow up post added August 31st, 2013 08:56 AM ------
Haha. Ok, I'll get with the program and sign up for AAA.
Old August 31st, 2013, 10:54 AM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
radar detector. =)
Old August 31st, 2013, 12:20 PM
Here's what you want.
Old August 31st, 2013, 12:32 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Originally Posted by d90boy View Post
radar detector. =)
I was gonna say radar detector.. hey ya never know. Shep, get in there and trace the wires! you gotta let us know what it was for when you figure it out.
Old August 31st, 2013, 12:40 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
It does look exactly like an early K40 Radar Detector Switch.
Old August 31st, 2013, 01:04 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
It actually did have a front and rear radar detector system as well as an alarm that the PO disabled. Hmmm...
Old August 31st, 2013, 01:10 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Sounds like youve found the culprit.
Old August 31st, 2013, 01:27 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Yeah, looks that way. Thanks for the suggestions guys.
Old August 31st, 2013, 01:50 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Yep early K40. Volume and gain (city/country settings)
switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
