Mystery Relay Sound - Defender Source
Old November 29th, 2011, 11:14 PM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
Mystery Relay Sound
Oh mighty defender gurus...
So I fire up the Landy yesterday and almost immediately, I hear a clicking sound like a relay flipping - similar to a turn signal left on. I check, nothing left on. I try the indicators and they make the usual clicking sound over the top of this mystery noise. The indicators are a slightly faster click-speed than the mystery noise. Tried the hazards - nope, not that either. Then I turn off the engine and remove the key. Lights are off. The mystery click continues. The noise sounds like its coming from behind the speedo dials, which I removed recently to replace the turn signal switch.
As I'm weighing up the possibilities between Poltergeist or Time-Bomb, I fire up the landy again, and as soon as I turn on the ignition, clicking stops.
Hasn't happened again for several days.
Anyone care to speculate?
Old November 30th, 2011, 08:00 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
My 97 Wagon did that periodically. It never did it long enough for me to track down what it was and it never changed how the car ran or drove. I've been waiting for a 90 to come into the shop with that issue so I could locate the issue, but its never come up again.
Email:
Old November 30th, 2011, 08:06 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Mine does this when I have the wipers on and use the turn signal....doesn't always happen and the clicking seems to come from behind the speedo. If I turn off the truck and re-start it stops. It never bothers me enough or does it enough for me to look for it. I think it is coming from a green box back there which I believe might be something to do with an alarm.
Old November 30th, 2011, 10:46 AM
brettm's Avatar
brettm
Brett
alarm is an interesting theory - there is an aftermarket clifford alarm installed that is somehow connected to the ignition switch.
glad it's no cause for concern. if it starts to happen regularly i'll try and troubleshoot and report back.
Old November 30th, 2011, 11:16 AM
Stormer's Avatar
Stormer
JP
2008 RRSC
I have the same issue on the 110 and I am having some of the electricals cleaned up. I'll let you know if he discovers the cause.
relay
AC relay in passenger area? artm Defender Technical Discussions 0 July 18th, 2005 09:53 PM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
