Mystery bolt on the transfer case - Defender Source
Old October 23rd, 2010, 03:18 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
On my '94 D-90, there is a bolt to seemingly nowhere on the driver's side of the transfer case between the transfer case and the frame rail. This bolt does not seem to go anywhere and when I take it out it's just an open hole that goes into the transfer case. Any ideas what this is? I noticed that the same location on a '94 disco has some electrical lead plugged into it. Is this a type of speed sensor? I tried searching but didn't come up with anything substantial.
Old October 29th, 2010, 11:29 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
The disco has a t-case oil temp sender there that the 90 doesn't. That what you mean?
Old October 29th, 2010, 11:58 PM
cbass's Avatar
cbass
Bradlee Duncan
Yep, that must be it. Is there any reason to install something like this on the D-90? Why would the disco have it and the D-90 not with the same t-case?
Old October 30th, 2010, 01:32 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
I'm sure you could put one in and hook it up to the trans overheat light easily enough if you wanted to. Seems to me that where it sits is above the oil level though so not sure how effective it is.
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
