So a couple of weeks ago the 90 would not fire up. I popped the hood and checked for spark, no spark. I pulled the ignition fuse and it looked fine, but I swapped it with the A/C fuse anyways. The truck fired up on the first crank and the A/C still worked. Oh well at least it starts.
Since then its happened a few more times. Each time if I pull the ignition fuse and put it back in, the truck will turn over on the next crank.
Any ideas? Am I resetting the ignition when I pull the fuse?
Matt
Matt
