My wierd stalling. Yes i searched :) - Page 3 - Defender Source
Old November 30th, 2012, 09:52 AM
... My motto is 'check by actually checking' ... many people 'assume' and then present it as fact
Old November 30th, 2012, 12:10 PM
landrovermanuk's Avatar
landrovermanuk
John Lindsay
1986 Land Rover 90, 3.9Efi
Very true.... I do trust my shop guys... However no one can know everything about a make of car and even if they do they'll still forget something eventually....
Land Rover 90, 3.9Efi Auto, Soft Top, NAS spec, Tangiers Orange.
Land Rover owners like it rough and dirty...
Old November 30th, 2012, 12:15 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
if you have new batteries and the same problem .. definatley perform a quiescent draw test , go through the usual senarios on how the vehicle is used most shops won't have the time or patients to actually wait and figure stuff out like this
No Mall crawler here
Old November 30th, 2012, 12:20 PM
Especially hard to do when it is linked to rain.
Old November 30th, 2012, 01:02 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
it is ? ever hear of a hose ?
Old November 30th, 2012, 01:05 PM
You saw my cars ... the answer is no.
My first lotus had a draw issue. Turned out when it rained the humidity was causing an issue with the ignition switch. No direct water was getting it, just when it was humid enough it would draw current.
Old November 30th, 2012, 01:34 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
like i said "go through the usual senarios on how the vehicle is used" when its raining and crappy out park the car and put the meter on it and just wait it will turn up .... most techs see this as a complete loser job .. i kind of like finding wierd shit like that
good luck on finding the cause
Old December 1st, 2012, 06:05 AM
landrovermanuk
John Lindsay
Looks like I'm going to have to dabble in the dark arts of electrickery as the shop is sure it is nothing to do with the leak. They told us there is definitely no permanent live in the rear of the car. So I open the boot lid take off the side cover and there is a light red light winking at me from the satnav.... So straight away I've found a live..... Thanks for all the advice....
Old December 17th, 2012, 10:34 AM
wantone
Rick Thompson
94 ST #1222
update. put i the new ignition module ran great for couple thousand miles. procrastinated on the alternator.... then it started stalling, missing again, but this time when it did it, it would not idle and it missed like a cyliner was not firing. the tach would delay a bit when it would rev for a second. if is shut it off and turned back on, immediately it would run fine again. (i did put a new stepper in also) so i threw out the new o'reilly's alternator and put in a rebuilt bosch unit. we will see how it goes....
Old December 18th, 2012, 09:14 PM
wantone
Rick Thompson
94 ST #1222
I put on a new 0/1 gauge neg battery cable from napa & bolted it to the cross member & then ran a short cable from the block to the frame & it did the trick.
stalling bjenk Defender Technical Discussions 5 May 7th, 2005 12:56 AM
I searched, I swear, for hardtop removal khatadin Defender Technical Discussions 2 April 15th, 2005 06:45 PM
Stalling RR? headdamage Defender Technical Discussions 5 March 20th, 2005 12:29 AM
Rear Name Plate - Searched First Eric Siepmann Defender Technical Discussions 3 October 29th, 2004 12:54 AM
Stalling problem and fault codes James Defender Technical Discussions 5 July 22nd, 2004 07:29 PM
