My turn for a "no Start" thread.... - Page 2 - Defender Source
Old May 7th, 2008, 04:03 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Service manual is basically no help here either. It keeps referring to "See ETM A1"
What the hell is ETM A1, and where do I find it?
My oil line fix
My 100k stopped odometer fix
Old May 14th, 2008, 04:45 PM
Hans's Avatar
Hans
Hans Haase
Still no luck here, blech.
Rigged up an LED to test the injectors, and they are firing. I'm getting spark. Tried tricking the coolant sensor to keep it in a proper running temperature range. Starting to suspect the fuel pump, but having a beast of a time getting the right fittings together to test the pressure.
-Hans
My oil line fix
Old May 14th, 2008, 05:16 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Are the plugs consistantly fowled? That is, have you replaced them only to find them fowled again?
While this is proabably left field, and a bit beyond my ken, have you considered your PCV system? Perhaps your PCV is crammed with particulates and thus, allowing the engine to run too rich, flooding the system and fowling the plugs.
DJ
Old May 14th, 2008, 07:42 PM
Hans's Avatar
Hans
Hans Haase
Plugs, up until recently, have been looking normal whenever I pull them. Even now, they aren't carbon fouled at all, but just look damp.
I also got a pressure gauge onto the fuel pump finally, and it's pushing 50psi no problem. Clamped down on the return line of the regulator to make sure the rail was getting enough of that pressure, and still no good.
Well, I THINK I found it. It's always the fairly new parts, isn't it? I went back to check the spark again, and while I had it earlier I didn't anymore. Went back and started all the ignition tests again. Spark from the coil to the block, yes! Really strong too. Spark from the plug wire to the block? Not anymore! Pulled the cap, did the coil wire over the rotor test, and she's sparkin away like she's NOT supposed to. Guess the rotor was slowly failing on me, and is just fried now. Grab a new one tomorrow and see how she goes.
-Hans
My oil line fix
Old May 29th, 2008, 03:01 PM
Hans's Avatar
Hans
Hans Haase
And she runs now. Must have been flooded all to hell too. Didn't fire off when I first put the new rotor in, but I let it sit a week and it fired up right away when I got back. She's pretty sluggish right now, and I get some burbling out of the exhaust when I let off the throttle, but it's progress. I just need to let it run for about an hour I think, to burn all that extra fuel out of the cats. One way or another though, the hard part is done.
My oil line fix
start
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
Turn signal--problem solved Davis Defender Technical Discussions 0 July 18th, 2004 08:13 PM
Thread rating options chrisvonc Community News & Announcements 0 July 2nd, 2004 09:49 AM
Thread hijacking! TwisteD90 Misc. Chit-Chat 19 March 6th, 2004 03:23 PM
