My turbo is dead :( - Defender Source
Old September 21st, 2010, 09:54 AM
My turbo is dead :(
Was heading home on Sunday on the interstate, when I suddenly lost power on rolling hills, doing 65 through rolling hills. there was a wizzing sound, and I thought my clutch might have given out and was slipping. I could still move with the wizzing sound, but much slower. I pulled over and tried some back and forth, and then put the xnfr out and back in just in case it was popping out of gear...no change.
got back on the interestate and starting going up hill a bit flooring it to confirm it was a problem. could only do 50mph at full speed, then in my rear view mirror I started seeing blue-grey smoke billowing out of the exhaust, smoking out all lanes. Pulled over and called AAA.
At a diesel shop now. They confirmed turbo. Oil through all IC lines. I dont' know how bad it is yet. They have a turbo shop they work with that will look and see if it is rebuildable. maybe, if they can get parts for the TGV turbo. I'm completely deadline right now, and a new turbo is $1500 from M&D. I'm guessing it was the internal oil seal. There was no explosion, so I'm hoping the internals and bearings are all still ok. Only 50k on this turbo.
If this shop can't rebuild this turbo, does anybody know a shop elsewhere in the country that can?
Sucks to be me. No MAR for me this year.
Old September 21st, 2010, 10:11 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Very sorry to hear that Mark. 50k seems very odd?
Old September 21st, 2010, 10:31 AM
damn-was looking forward to finally meeting you. I think you should come even without the 110.
Old September 21st, 2010, 12:56 PM
Chaucer
Will
93 110 | 97 90
Sorry to hear man.
Old September 21st, 2010, 01:34 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I doubt the turbo is the problem
They can be bought in the states.
Maybe a split intercooler hose
legend in my own mind
Old September 21st, 2010, 01:51 PM
Thanks for chiming in Jim. My diesel shop pulled the hoses and the IC and hoses were filled with oil. They sent the turbo out for evaluation. I don't know what if anything I did to blow the seals, but my biggest regret is not taking you up on your offer to install an EGT gauge while you were installing the engine. Anyway, they are putting a bung in the manifold for me while the turbo is off.
Thanks to the EVO thread for identifying the turbo model number. still need to verify it matches mine but now I have something to search for locally.
Old September 21st, 2010, 02:12 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Did you always idle the vehicle for a few minutes after coming off the highway before turning it off so that the turbo would have oil-flow and time to cool down? 50K seems low under any circumstances other than oil starvation, checking oil pressure might be a good step when fitting the new/rebuilt unit.
AFAIK EGT is unlikely to be at fault, the first thing to go is the piston crown when you're running too high.
Old September 21st, 2010, 02:13 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
can you report back what the difference in drivability is w/o the turbo? just curious
sorry to hear about that.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old September 21st, 2010, 02:21 PM
As mentioned, think of a slipping clutch. foot on floor and half the speed. flooring it got me to 50mph. aka sucks.
I have never come straight off the freeway or high speed to a full stop and shut down without a few moments of idle.
Old September 21st, 2010, 03:12 PM
I drove a Penske truck across Kansas one time after the turbo went out, symptoms like you describe (which makes sense for what is effectively and NA diesel) and fuel consumption went through the roof.
Old September 21st, 2010, 04:25 PM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
Exact description of when my turbo went on my Td5 in 2005...sorry to hear that dude...pricy fawkers they are...
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old September 21st, 2010, 04:30 PM
D90user's Avatar
D90user
steve
Mark, did you mess with your boost and fuel at all?
I'm trying to reconcile the failure at 50k thing...
Old September 21st, 2010, 04:59 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I am with Pendy, anyhow a little oil in the IC charge piping is normal, there is no way they were "filled" with oil. It kinda sucks you didnt have an EGT on the truck, did you have a boost gauge? If only you hadn't gone straight to a diesel shop, at this point they can tell you anything and get away with it. I popped an IC hose clamp on my cummins once hauling a truck in SC and lost a LOT of power, lots of smoke, etc. I have seen split hoses and clogged filters on LR turbo diesels cause symptoms a lot like you described too.
Old September 21st, 2010, 07:09 PM
I have not touched fuel or boost. No intentions to until I get my installed but not hooked up egt and boost gauges in place (based on recommendations of this forum). I was deliberating on how to tap my manifold, since the 2.8 manifold does not come with any convenient place to install a probe like the 300 tdi does.
anyway, this shop is trusted as the owners are good friends of my good friend, who is a Colonel in the national guard and a charlotte police officer. we'll see what they say. they didn't say the IC was "filled" with oil, but they did see plenty of oil pre-removal through the pipes. I'll post my findings for posterity.
Old September 21st, 2010, 07:37 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
oil in the hoses can be related with engine breather connected with air intake.
- Charles Eames
Old September 21st, 2010, 07:42 PM
shamptonrover
jeffrey scannelli
1998 110tdi
we have a warehouse in PA that may have the turbo send me any part numbers you have, also make sure whoever does this job for you removes the intercooler and sends it out to a radiator shop and gets it cleaned out!
Old September 21st, 2010, 08:08 PM
agreed. they are doing that. Per Keith's EVO thread, the model number should be Garrett GT2256V. I need to confirm with the shop, as I haven't seen the turbo off before to confirm what's stamped on it.
Old September 22nd, 2010, 04:22 PM
update: it's official. the turbo blew up internally.
Old September 22nd, 2010, 10:28 PM
crobinson
Chris Robinson
97' D1
I just got mine back today from the turbo shop for a rebuild. Garrett T250. Looks great just got to rotate the waste gauge around. $334 before tax
Pendy referred this guy.
Jeff Amann
Turbo Auto
4403 Charlotte Ave.
Nashville, TN 37209
615-383-6242
ID:	31409   Click image for larger version
Name:	002 - Copy.JPG
Old September 22nd, 2010, 11:53 PM
DD90's Avatar
DD90
DD
94 D90
That turbo is nice bling!
Can someone explain why there would be oil in the IC as a result of the turbo failing??
Trying to understand.
darn! my ac is dead! =( scubadanster Defender Technical Discussions 16 August 2nd, 2005 05:32 PM
HELP, HELP Dead D90 in CT januconn92 Defender Technical Discussions 16 July 8th, 2005 08:20 PM
remote turbo? Rod Hayward Defender Technical Discussions 7 January 11th, 2005 04:16 PM
Need a DEAD EFI computer for parts Hans Wanted 0 December 5th, 2004 03:21 PM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
