My POS Safarigard 3L kit - Defender Source
Old May 20th, 2012, 11:54 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Angry My POS Safarigard 3L kit
After an awful long time and a couple hundred Euros gone in the missing centerlink, spacers and hardware I missed, I spent (or threw away) the weekend trying to install the SG 3L kit.
After 2 days under the truck eating dust, this is where I am now.
Photo 1 shows the "clearance" between the rockguard and the diff, with the forward and rearwards bolts in place; bolts which use the swaybar holes don't line up, so I guess I'll have to use smaller ones
Instructions say "grind slightly" if there a clearance isssue, and "this should be minimal".
Minimal my @rse.
I think I'm close to poke a "minimal" hole in the RG, and the area I had to grind is now hair thin probably, so I might have created a nice weak point
Photo 2 shows the area affected by the "slight clearance issue".
Photo 3 shows the clearance tierod has with both ends in place (yet not tightened).
Plenty of room it seems. Eh.
Tomorrow I'll have to go to my fabricator and have a flat bar cutted and drilled to work as spacer and fill the gap.
Then, supposing all the rest will be fine (.......), I'll bring the Cube out for a test spin with this bodged setup; if anything's wrong, I'll throw it all in a corner and get back to radius arms.
I'm surprised nobody ever showed up to SG when they still were in business, and beat the cr@p out of those guys.
Tolerances are ok and taken in account (mostly), but a blind monkey could have done better.
I'm glad I bought a leafsprung Rover.
So I won't have to deal with garbage like this again to gain some articulation.
ID:	51848   Click image for larger version
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old May 20th, 2012, 07:16 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Bummer. I feel your pain
Back in the day when I installed a pile of those I never had any one of them fit right out of the box. They were also incredibly inconsistent. I tried to work it out with SG but in the end I just cut them all up, reassembled and painted it with frame paint (cause the powdercaoting also sucked). I still have one kit sitting in a box for spares.
Matt Browne
Old May 21st, 2012, 01:46 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Hi Matt,
thanks for symphatizing.
I am evaluating to cut it to pieces as well (for the bin tho), re-draw it and have a new one made by a fabricator with both eyes in shape.
Shame after a wasted weekend, I would've expected to have the Cube back on the road, and not sitting on jacks still...plus I'm tired of pouring more money and time in this thing.
I'm tempted to grind even more until it (MAYBE!!!) slips in and bolts to the diff (if it'll ever do...) like it's supposed to do, but neither I want to cut a hole in the boxed section...?!?!
The "spacer" plate alternative plan, on the other end, would be the quintessence of this bodge installation...
On top of this, it's raining cats and dogs.
Lovely.
Michele
D90 VNTdi
[O]===[O]
Old May 21st, 2012, 06:24 AM
HA Ha ha ha ha ha....HAH!
Old May 21st, 2012, 06:38 AM
Cube II's Avatar
Cube II
Michele
1997 D90
I'm glad I'm amusing you Bill
Michele
D90 VNTdi
[O]===[O]
Old May 21st, 2012, 09:03 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Weld a spacer plate to it and paint and you'll forget you did it in no time.
Matt Browne
Old May 21st, 2012, 09:18 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Will squeeze one in and see if it bolts up ok, although I'm tempted to grind it "slightly" more...
Michele
D90 VNTdi
[O]===[O]
Old May 21st, 2012, 11:51 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
shit, I haven't put mine on yet and I hope I don't have the same problems.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 21st, 2012, 01:48 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
I was lucky and got mine second hand and it had already been fitted and grounded down. It fit pretty good with with help of a bottle jack and a big ass hammer.
Here's a pic - you can kinda see how much was ground off
Old May 21st, 2012, 02:39 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Mine is 2nd hand too...in a way.
Been test fitted to a previous D90 here in Italy and soon binned.
I wonder if they'll ever manage to fit it, but there are washers marks around the diff hole,
so I'd think they someway made it?
I can't see any grinding on yours...?
I touched your pic up to show the affected area.
Thanks.
P.S.
My "spacer" will be ready tomorrow, but I'll attack again with the angle grinder.
Should I ended up with an hole in it, to hell, I'll have a better one made from scratch.
Now it's getting personal B-(
Michele
D90 VNTdi
[O]===[O]
Old May 21st, 2012, 03:04 PM
ini88's Avatar
ini88
Daniel Marcello
Michele is your tierod heavy-duty as in thicker or are you running the stock tierod?
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 21st, 2012, 03:09 PM
Cube II's Avatar
Cube II
Michele
1997 D90
It's stock, I don't think an HD one would work...I still doubt the stock will do!
I still have my Rovertracks rod, but it's not the straight type, so I can't tell.
------ Follow up post added May 21st, 2012 09:13 PM ------
@ Jake: could you please take a couple of closeup shots?
Michele
D90 VNTdi
[O]===[O]
Old May 21st, 2012, 03:59 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Well that was the only pic I have with it not on the truck. If you zoom in on the pic you can see where it has been hit with the grinder - I painted over it. Mine fits with the QT HD tie rod no problems.
Old May 21st, 2012, 04:13 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Uhmm...will check again tomorrow.
Thanks!
Michele
D90 VNTdi
[O]===[O]
Old May 21st, 2012, 04:19 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Thanks!
You could also try grinding on the diff housing bit.. I would but I'm a little crazy
Old May 21st, 2012, 04:37 PM
Cube II's Avatar
Cube II
Michele
1997 D90
I did think of it, but holy cow, no.
Michele
D90 VNTdi
[O]===[O]
Old May 22nd, 2012, 11:27 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Thumbs down
Update:
while waiting for the spacer to be done, I did buy a new angle grinder and "slightly" grind the damn rockguard again...I did try to keep it to a minimum, but I went through the top layer of steel and hitted the one below until it now looks "porous". So the thickness is close to zero there, and I can see minimal light if I look inside the boxed section now
I did test fit it again, and it slided in position, right up to the diff holes!
Hooray I thought (you damn pig), but...
...fit the bolts for the millionth time in the forward holes...
...tap tap tap
...ok
...move on to the rearward holes...
...tap tap ta...WTF...HOLY COW HOLES ARE NOW MISALIGNED!!!!!!!!!!!!!!!!!!!!!!!!!
D'OH!
I'll stop by my fabricator in an hour to get the spacer, while there I'll put the damn rockguard under the press drill and bore those stupid holes out!!!!!!!!
Then I'll probably refit radius arms and re-draw the whole damn thing as needed
It has really drained my will away...
Michele
D90 VNTdi
[O]===[O]
Old May 22nd, 2012, 12:12 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
You need to take a drill, let the rock guard hang and put a piece of wood of metal behind it and bore the holes out. Mine are pretty big but I used a couple bigger washers and it works fine.
I wouldnt worry about a small hole in the rock guard it's still going to be more than solid.
Old May 22nd, 2012, 01:15 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Just got back from the "shop", redrilled the holes and have my spacer with me.
I'll give it another try tomorrow.
But I forgot a detail...the pretty much "special" diff bolts...I'd need longer ones with the added spacer, and can't find them anywhere.
Oh yeah!
Ypeeeee...
Michele
D90 VNTdi
[O]===[O]
Old May 24th, 2012, 04:06 PM
Cube II's Avatar
Cube II
Michele
1997 D90
I refitted the radius arms today...
Michele
D90 VNTdi
[O]===[O]
kit
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
SG JEK 3 Suspension Kit 97D90 Defender Technical Discussions 7 September 23rd, 2005 10:00 PM
Kenlowe Twin 13" HD Fan Kit Barnett Childress For Sale - Parts 1 September 7th, 2005 04:01 PM
SafariGard droop kit Joe P Defender Technical Discussions 3 April 15th, 2005 07:57 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
