My POS Safarigard 3L kit - Page 4 - Defender Source
Old September 28th, 2012, 09:14 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Did I say I'm still alive and it's running?
(despite a few weird things)
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old September 28th, 2012, 10:40 AM
Cube II's Avatar
Cube II
Michele
1997 D90
So far, it's silent
(touching wood)
Still...some weirdness.
I spent more money on bolts and nuts, I needed a replacement for the DS upper arm (done, perfect), and I wanted slightly longer bolts for the center link (what I have now are just too short to put a washer each side, which I don't like it)...the replacement I got, accordingly to the original parts list, matches perfectly the ID of the metal sleeve.
Shame, it's too big for the holes in the crossmember and rockguard tabs
So I had to refit the old ones, which are slightly narrower and rattle in the centerlink.
I will probably drill the tabs out as soon as I'll have the chance...and will.
Now I need:
1)a different diff guard, my Qt won't fit anymore, I'm ordering a weld-on guard from Gwyn Lewis
2)longer shocks (when I'll get a job again)
3)external mounts, I'd like to have some custom ones made , will doodle something...
Michele
D90 VNTdi
[O]===[O]
Old September 28th, 2012, 11:04 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Although I'd love the sewer cap mod!!!! and my fabricator is close, it would involve pulling the axle and gutting it, and welding etc...which I can't do right now, this truck spent most of its time stopped for some silly job to be done than idling on the trails...I want to use it before the winter comes, as much as possible.
Gwyn's guard has decent openings on sides, I guess in similar style to my Qt guard...it should be easy to clean with a hose.
I could chop my Qt, but I'll keep it, just in case I'll have to get back to radius arms.
Shock mounts: I plan well ahead
and a couple of RRC external shock mounts have been sitting on the shelf for...2 years? 3? By now...
But yes, I'd like to going huge this time...or, better, long
I think I'll shoot for 12" short body 7100s (running 10" at the moment and I could max these out with slotted bushes),
I know some run 14" but I see packaging issues...
Michele
D90 VNTdi
[O]===[O]
Old September 28th, 2012, 11:13 AM
Naplm00
Matthew
Why would you have to gut the axle to mount the sewer cap? I thought most guys were doing this with the axle still in the truck
Old September 28th, 2012, 11:18 AM
Cube II's Avatar
Cube II
Michele
1997 D90
I guess I'm a weirdo
Actually, I don't have a proper garage with a lifter to work in...and I like doing things the comfortable way...so, laying the axle on my fabricator's table, where he can cut and weld and touch up paint comfortably...done once, done well...
(Edit: ooh, I still had the full Toy conversion in mind, which I planned years and years ago, which involves gutting the axle...there, confusing me)
Gwyn's guard should do...three tabs, and you're ready to wheel.
Michele
D90 VNTdi
[O]===[O]
Old September 28th, 2012, 11:22 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Even to pull the front third you'd have to take the whole 3 link apart.. It's a nightmare, probably the worst part of the design.
Old September 28th, 2012, 11:28 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Urgh...don't remind me...
Even if, having pulled that pig a hundred times, I'm quite skilled and fast now!
Michele
D90 VNTdi
[O]===[O]
kit
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
SG JEK 3 Suspension Kit 97D90 Defender Technical Discussions 7 September 23rd, 2005 10:00 PM
Kenlowe Twin 13" HD Fan Kit Barnett Childress For Sale - Parts 1 September 7th, 2005 04:01 PM
SafariGard droop kit Joe P Defender Technical Discussions 3 April 15th, 2005 07:57 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
