My POS Safarigard 3L kit - Page 3 - Defender Source
Old September 10th, 2012, 05:29 PM
The nut is meant to be tightened when it bottoms and you are supposed to tighten it with a lot of torque to prevent it coming loose.
So you are saying that you don't think the bushing are compressed enough? Are they new or used? Are the washers ones that came with the kit?
Old September 10th, 2012, 05:49 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
The kit has been test fitted once probably to another Defender, and then pulled off.
Bushes and washers look okay, no sign of wear as far as I can see.
What I mean is, I don't think it took me a lot of torque to bottom the nut, I'm quite sure it took less than the 176 Nm suggested by the manual when tightening the stock radius arms nuts, just to say....that's it...
I'll Loctite everything...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old September 10th, 2012, 08:41 PM
It should not take much torque to bottom the nut. After bottomed then you torque it.
Old September 10th, 2012, 09:25 PM
what he is saying is that he has reached the end of the threads. If he keeps spinning it it will strip it. It wont make it to the proper torque without stripping it. I think he needs thicker washers, or more washers.
-Jeff
No, I do not think so. You are supposed to hit the end of the threads. That is how it works... I think he is saying that he does not think the bushings have compressed adequately. They are not supposed to compress much.
Old September 11th, 2012, 02:46 AM
Cube II's Avatar
Cube II
Michele
1997 D90
-Jeff
^_____^ This...!
Michele
D90 VNTdi
[O]===[O]
Old September 11th, 2012, 09:28 AM
That makes no sense unless the nut is stripped. Is the correct washer being used?
Old September 11th, 2012, 09:34 AM
Cube II's Avatar
Cube II
Michele
1997 D90
washers
Yup! Stock washers recycled, as per instructions...
Michele
D90 VNTdi
[O]===[O]
Old September 11th, 2012, 10:59 AM
So you are saying the nut spins? If so, it is either stripped or the wrong sized nut and you should not be driving it.
Old September 11th, 2012, 12:11 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Erm,
no, it doesn't spin at all...I'm saying it just reaches the shank and stops there, I believe, without putting silly amount of torque on it...unlike with the stock radius arms.
And I find it odd.
Is it just me?
I fear I can't explain myself clearly here.
Michele
D90 VNTdi
[O]===[O]
Old September 11th, 2012, 12:57 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Buy a couple washers and put them at the end of the shank before the first bushing washer.
I have used these on trailing arms http://www.mcmaster.com/#cadinlnord/98040a110/=j8wtsc
Old September 11th, 2012, 01:25 PM
Originally Posted by Cube II View Post
Erm,
And I find it odd.
Is it just me?
That is how it should be. You should not be putting any real torque on before it bottoms, even with the stock arms.
Old September 11th, 2012, 01:56 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Maybe here goes the misunderstanding...the nut doesn't bottom because of the bush, instead, it squeezes the bush until it comes to the shank, and can't go any further, so I can't torque anything more. This is my feeling.
Better now?
Anyway, it's late now, will take a pic tomorrow as per Jeff's suggestion, and/or measure the thread and compare it to the stock one.
And eventually I'll buy a couple of big bad washers.
Thanks all for the interest so far.
Michele
D90 VNTdi
[O]===[O]
Old September 11th, 2012, 02:17 PM
That is what is suppose to happen. The bush is not suppose to stop the nut. The nut should be tightened hard against the shank.
Old September 11th, 2012, 02:19 PM
Cube II's Avatar
Cube II
Michele
1997 D90
You think I shouldn't bother anymore then?
Michele
D90 VNTdi
[O]===[O]
Old September 13th, 2012, 04:14 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Unhappy Again on threads.
Time for more
I bought some big washers and a few minutes ago I gave it a try.
While there, I found out the nyloc nut has a lot of play on the male thread of the SG control arm and minimal play on the stock radius arms...wtf?
I re-used the stock nylock nuts as the arms in my kit came without.
I'm getting sick of this all...
Isn't the thread on the SG arms supposed to be the same as stock? Or is it not?
Michele
D90 VNTdi
[O]===[O]
Old September 13th, 2012, 05:01 AM
Cube II's Avatar
Cube II
Michele
1997 D90
M20x2.5 thread??
Michele
D90 VNTdi
[O]===[O]
Old September 13th, 2012, 05:52 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
A washer should serve as stop between the nut and the shank, not just nut against shank. I have couple of three links (NIB) at the shop..........can compare parts see if you have some thing wrong.
Matt Browne
Old September 13th, 2012, 05:58 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Matt! Good to hear from you!
I did shoot you a mail some time ago, about this
I'd be glad to check a few things...threads pitch & nuts first?
Michele
D90 VNTdi
[O]===[O]
Old September 13th, 2012, 09:46 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Yes 20x2.5 sounds right? Are the nuts new or used?
Why dont you just buy my 3 link. It fits and works
Old September 13th, 2012, 09:52 AM
Cube II's Avatar
Cube II
Michele
1997 D90
1. Both, new and used
2. LOL, yeah, right what I need now
Michele
D90 VNTdi
[O]===[O]
kit
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
SG JEK 3 Suspension Kit 97D90 Defender Technical Discussions 7 September 23rd, 2005 10:00 PM
Kenlowe Twin 13" HD Fan Kit Barnett Childress For Sale - Parts 1 September 7th, 2005 04:01 PM
SafariGard droop kit Joe P Defender Technical Discussions 3 April 15th, 2005 07:57 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
