My POS Safarigard 3L kit - Page 2 - Defender Source
Old May 24th, 2012, 05:16 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Originally Posted by Jake1996d1 View Post
You need to take a drill, let the rock guard hang and put a piece of wood of metal behind it and bore the holes out. Mine are pretty big but I used a couple bigger washers and it works fine.
I wouldnt worry about a small hole in the rock guard it's still going to be more than solid.
don't you have a 'pink' link also...
Old May 24th, 2012, 05:40 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
the good ole stinky pinky
------ Follow up post added May 24th, 2012 03:41 PM ------
Originally Posted by Cube II View Post
I refitted the radius arms today...
What happened?! I thought all you needed were some bolts?
Old May 24th, 2012, 08:41 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
This is all normal stuff for fitting one of these.. I have installed several and on every one you have to grind that edge and shim under the diff.. As for your HD tie rod, I have a solid SS RYM one that I turned down the center of it on the lathe so it did not rub the inside of the rock guard...
I still have bushing sets if anyone needs
Legend in My Own Mind.
Old September 6th, 2012, 06:32 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Post Lenght of upper arms...
Time for an update.
I went back to it today, with a spacer and longer, common bolts (I re-threaded the diff holes).
After 4 hours of puffing, hammering, sweating and swearing I did manage to fit the damn thing in some way...it's not straight yet and I had to fit washers everywhere to fill the gaps.
I plan to finish tomorrow, either adding the spacer under the diff or boring out the holes of the rockguard (therefore no more need of diff spacer), which are of course misaligned here and there...
I found out the upper arms are shorter than the stock radius arms though ...did anybody ever notice or are just mine?
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old September 8th, 2012, 07:36 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Question
Attached a couple of pics showing the stock vs. Sg arms...
Also, I found out that there's not enough tread to fully tighten the bolts at the chassis end...I guess I'll try and fit LR bushings, and see it it makes a difference...?
I don't think it's very safe to hit the road with sloppy arms...
What else...oh, as I removed the arms to check the thread depth, they now fit no longer...everything was so misaligned and jammed that I ruined the thread on the bolts...
I'm tempted and almost ready to bin everything.
I will bore some holes out.
Again.
Suggestions about the bushings/short threads anyone?
Experiences??
After 2 days I'm still stuck with the Cube on jack stands...
ID:	57270   Click image for larger version
Michele
D90 VNTdi
[O]===[O]
Old September 8th, 2012, 09:11 AM
Hi michele...aren't the sg 3 link arms supposed to have an additional piece in front?
The bushing on the arm goes into a crescent shaped piece that goes under the axle, no?
Old September 8th, 2012, 09:25 AM
Picture 2: http://www.defendersource.com/tech/3link.html shows the arms mount to a different place at the axle end.
Old September 8th, 2012, 10:13 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Ok they are shorter to compensate the different mounting point, it would make sense...
Still the bushes look wrong and I can't tighten the arms at chassis...
I want to kill someone...
Hi Ed, don't know of any other additional piece...at front there's a tube where a bolt goes through, while at rear they're threaded as the stock radius arms...
Michele
D90 VNTdi
[O]===[O]
Old September 10th, 2012, 12:17 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Smile
Job done.
A few details are still on the list, like the bolts I couldn't slide through the anti-roll bar mounts (holes being misaligned), short bolts to be changed here and there, and the upper arms which point slightly upwards (having almost no lift) and have not enough thread at the chassis mounts...
I'll try adding shims/washers.
Springs are still my "soft" ones, but surprisingly it doesn't seem scary on road.
I haven't broken yet the 80 Km/h barrier tho, nor done any "ramp" test.
ID:	57363   Click image for larger version
ID:	57365   Click image for larger version
Michele
D90 VNTdi
[O]===[O]
Old September 10th, 2012, 01:05 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Hey Jeff,
trouble is, the threaded part of the upper arms seems too short,
and the nylock nut goes all the way down until it jams, there's no thread left to run on.
As to the holes, after 3 days of fitting and refitting, I was too tired to pull the rockguard again to bore the holes out, my mistake, I should have done it first thing, I'll try soon with that thing in place.
I didn't force the bolts through, because I did it with the upper arms (holes misaligned again) and after a couple of tries the thread was ruined and I had to bin the bolts...
P.S.
Anybody else with a 3-L willing to remove nut & bush and measure the threaded lenght for me?
Michele
D90 VNTdi
[O]===[O]
Old September 10th, 2012, 03:35 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Will measure mine tonight. They don't use the bushings from the radius arms if that's what you're trying to do.
Old September 10th, 2012, 04:15 PM
I do not understand what you are meaning. The nut is supposed to be tightened until it bottoms into the unthreaded section. As long as there is enough thread for the nut to be completely on, it is long enough.
Old September 10th, 2012, 04:21 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
He probably things the bushings are compressed enough. And if he tried to use his old wore out radius arm bushings they probably arent
Old September 10th, 2012, 04:30 PM
Basically... The unthreaded part should be the same length on the stock ones and the new ones assuming they are both designed for the same era radius arm bushings..
Old September 10th, 2012, 04:36 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
They aren't the same. bushings the 3 link uses a daystar bushing.
Old September 10th, 2012, 04:43 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Thanks!!
Well the idea crossed my mind but I left the SG bushes in place...
Michele
D90 VNTdi
[O]===[O]
Old September 10th, 2012, 04:50 PM
OK, Michele... You then need to explain what exactly is wrong... There is more than enough thread to fit the nut.
Old September 10th, 2012, 04:53 PM
Cube II's Avatar
Cube II
Michele
1997 D90
I'm totally lost...here, LR bushes Vs. SG ones...
They're just slightly smaller. difference is minimal.
I don't know if they're supposed to be less tight (to better deal with increased flex??) or if the arms I got are wrong...or if I am missing something else...
The trick is in the thread I guess...?
Truck drives just fine, but I don't want any ticking bomb tho...
ID:	57385   Click image for larger version
Michele
D90 VNTdi
[O]===[O]
Old September 10th, 2012, 05:01 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
I figured your old Lr bushings were wasted. As long as that nylock is on there and the bushings are slightly compressed your fine. If you're still worried about it use some red loc tite
Old September 10th, 2012, 05:04 PM
Cube II's Avatar
Cube II
Michele
1997 D90
There is enough thread to fit the nut, but the nut goes all the way up to the end of thread without putting great effort, and my impression is that I can't tighten it properly.
I might be wrong, but this is my feeling...make any sense?
I'll remove the nyloc nut tomorrow and check, while putting some Loctite there...
Michele
D90 VNTdi
[O]===[O]
kit
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
SG JEK 3 Suspension Kit 97D90 Defender Technical Discussions 7 September 23rd, 2005 10:00 PM
Kenlowe Twin 13" HD Fan Kit Barnett Childress For Sale - Parts 1 September 7th, 2005 04:01 PM
SafariGard droop kit Joe P Defender Technical Discussions 3 April 15th, 2005 07:57 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
