My plastic stuff is breaking, what is next? - Defender Source
Old June 23rd, 2011, 05:43 PM
RickM
Rick Mabus
95 D-90 ST
Hey guys. I have a 95 d-90 with 75K miles on it and all my plastic stuff is starting fail. Latest was my fuel pump. Prior to that was a key tumbler. Prior to that was my high pressure oil lines.
What do you all suggested I get prepared for next if history is a guide.
Old June 23rd, 2011, 07:42 PM
The plastic stuff inside the truck?
If it is all the engine stuff, the trucks don't like to sit around, so try and stay on the regular maintenance.
Welcome back!
Old June 23rd, 2011, 11:27 PM
RickM
Rick Mabus
95 D-90 ST
You know it sat garaged for a long time while I was using a f250 as a daily driver. I sold that hunk of crapola and went back to my d-90. And that might be the issue. The stuff that is breaking really is a stuff like plastic around my fuel pump. The plastic casing an stuff. The other stuff is the little small valves on the side of the fuel tank. Another example is the plastic crapola around the key tumbler. I recently preplaced a starter and while leaning over the side of the truck I cracked the plastic window washer tub. My concern is this. I can handle a dash breaking and stuff but I am wondering if there are items in the mechanic area whether it be suspension, or drivetrain etc.
Old June 24th, 2011, 12:38 AM
No real plastic in the drivetrain. I am guessing age and texas heat have weakened the plastic in the truck. The trim piece around the speedo and tach seems to be the most cracked plastic on D90s I see.
little plastic thin piece that is glued down to cover the light near the heat switch d90guyinla Wanted 10 February 5th, 2013 05:01 PM
Misc stuff dave_lucas For Sale - Parts 8 March 23rd, 2005 01:47 PM
Soft top plastic windows paulb Defender Technical Discussions 8 March 22nd, 2005 08:58 PM
