my last oil cooler line ? - Defender Source
Old February 2nd, 2006, 08:41 PM
if i take and leave the oil cooler lines off long enough to get rebuilt is it possible that ill loose the prime to the oil pump? thanks
Old February 2nd, 2006, 10:39 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I blew an oil cooler line by the side of the road. I removed the adapter on the filter housing and put the filter back on to drive the car. You can do the same and drive the car while you have the lines rebuilt, or just start the car to refill the system and maintain prime. I left the oil cooler lines off and have no plans to reinstall them.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old February 3rd, 2006, 08:29 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
"Rob Dassler, on the cutting edge of common sense"
There. -A quote for your sig. line.
I've wondered for a while now if the oil cooler was a dubious benefit. My ignorance of what the downside could be has kept me from trying that.
Do you think it will make a difference on a hot summer day?
thanks
Rod
Old February 3rd, 2006, 09:28 AM
Roadsiderob
Robert Dassler
1994 D90
Well,
Early Classic Range Rovers did not have them and in 2003 or 2004 Land Rover deleted them from the D2...said hot weather testing confirmed that they were not needed. I got a 5-7 psi pressure increase without them as well. If you tow heavy stuff or run in really hot conditions, you may want them, but I am having no problems without them on my D90 and have no plans to refit them.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old February 3rd, 2006, 09:44 AM
I'm with Rob! That dam sandwich plate for the oil cooler was what killed my last engine! I'll be removing mine on my next oil change.
Old February 3rd, 2006, 10:56 AM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
So on removing them, do you plug the cooler side?
bill
Bill
Old February 3rd, 2006, 11:34 AM
pendy's Avatar
pendy
jim pendleton
89'd90
bill
If you search and read posts about this. You will find pictures of the sandwich plate. That is what you remove. You may understand this. But we do not want anyone else to just plug the cooler lines.
And the open holes on the radiator wil not effect cooling. You can plug the radiator fittings to keep dirt out. Plastic plugs would do.
4.0 engines do not have this option for you web wheelers.
I like the idea of going to a smaller line size external cooler. 1/4 or 5/16. I bet oil pressure could be maintained this way. And the true thermostat one of our members displayed is a good option. I still think the early truck had thermostats for oil coolers.
A Franz external oil filter and smallish external oil cooler would be the bomb. So run two oil filters. One external bypass style and the regular main.
JP
legend in my own mind
Old February 3rd, 2006, 11:44 AM
Roadsiderob
Robert Dassler
1994 D90
Good points Jim!
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old February 3rd, 2006, 01:03 PM
Awwww dam! THanks for the reminder Jim, forgot I don't have the sandwich plate with the 4.0. Looks like I'm stuck with it for now.
Old February 3rd, 2006, 01:27 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Well, if you really wanted to take it out, you could always do a short loop-line from the output to the input.
-Hans
My oil line fix
My 100k stopped odometer fix
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
Oil Cooler line kit! Eric Siepmann Defender Technical Discussions 22 February 20th, 2007 10:09 PM
old oil cooler line Abrooks Wanted 1 March 17th, 2004 06:52 PM
