My front end shakes - Defender Source
Old September 16th, 2014, 12:33 PM
Pinballking2's Avatar
Pinballking2
Andrew O'Rourke
1997 Defender NAS
My front end shakes
Just replaced all tie rods, drop link, all shocks and front stabilizer, had alignment done and seems worse than before?
Any ideas...
Old September 16th, 2014, 12:37 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Swivel preload was my cause. Pan Hard Rod bushings need a look, too. And check radius arms.
I am still amazed that the swivel preload took away my "death wobble". But there it is.
Old September 16th, 2014, 12:40 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Tires are properly inflated and balanced right?
Old September 16th, 2014, 12:47 PM
Pinballking2
Andrew O'Rourke
1997 Defender NAS
Balancing and tire pressure will be checked?
Had a shimmy before I replaced all the suspension bits, but now it is much worse
Do we have a technical section I could look up swivel preload ect?
I did a search for "Front end shaking" and got nada?
Any help would be appreciated
Want it fixed but need to understand the problem, before I let someone mess with my D
Andy in New York
Old September 16th, 2014, 01:30 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
http://www.landroverresource.com/ For rave manual detail the proceedure. Do a search under death wobble
Old September 16th, 2014, 01:35 PM
Matt223081's Avatar
Matt223081
Matthew Scanlon
84 D90 200TDI
Check your Panhard bushings first, I went through the panhard bushings on two trucks shortly after lifting them. The quick easy way to see if they are shot is to have someone rock your truck back and forth as you are looking at them, if there is a lot of play start there. If you have a lifted truck it is always a good idea to install an adjustable panhard rod to center the axle under the truck.
If the bushings are good check the swivel preload
http://landroverforums.com/forum/dis...preload-36607/
'06 Discovery 3
D90 trail truck project
Old September 16th, 2014, 01:49 PM
rankar's Avatar
rankar
what's basically happening is that you have a mass, your rover, and it converts energy to rotational kinetic energy. somewhere between the energy conversion of the engine to the rotational kinetic energy, you are displacing energy along a varying degree of amplitudes.
so you have to ask yourself, what's the greatest probability (path) that energy is being displaced along the amplitude rather than forward kinetic motion? start with the tires, wheels, swivel, etc. anywhere there is a conversion from rotational kinetic energy to forward momentum.
Old September 16th, 2014, 02:19 PM
RickM
Rick Mabus
95 D-90 ST
To add to your list of culprits, and to provide a simplified thought to what ranker just posted, have your checked your ujoints on your front and rear drive shafts lately? seams to me that something causing this was being muted some but worn suspension parts. Now that your parts are all snug, it is amplifying your problem. I have had a similar witch hunt on my wife's suburban and finally determined I have a damaged rear drive shaft.
Old September 16th, 2014, 04:21 PM
Swivel pre-load is a very common cause of what you describe. Deal with horse before zebras.
Old September 16th, 2014, 04:49 PM
RickM
Rick Mabus
95 D-90 ST
My preloads are on my short list for the fall season of garage time.
Old September 16th, 2014, 04:51 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
I had the same issue, I replaced the pan hard bushing and did the pre tension on the swivel pins at the same time, problem solved. On the note of while you're at it, if your truck is old, replace the pins and bushings and seals at the same time, ask me how I know?
------ Follow up post added September 16th, 2014 03:53 PM ------
I love this answer,
Old September 16th, 2014, 04:59 PM
rankar's Avatar
rankar
I should've defined amplitude. Amplitude is the amount of displacement that one of the parts is making from its point of rest.
Old September 16th, 2014, 05:39 PM
Pinballking2
Andrew O'Rourke
1997 Defender NAS
Thanks All
Rave and Chris's pictorial repair helped a great deal.
Think all right, the problem existed before I replaced all the front end stuff and when I did it put a fine point on that fault.
Balance, check inflation and preload inspection are all on the to do list.
I am on New York and would look to assembled experts to who you recommend for care and feeding of our Defenders?
Heard of a guy in the Bronx? Near Pelham Parkway?
Any info?
Thanks again
Andy in New York
------ Follow up post added September 16th, 2014 05:42 PM ------
Bye the way, I noticed oil/lube seepage from the bottoms of the swivels, like weeping in a way, Would this be related to the Pre load situation?
Old September 16th, 2014, 06:48 PM
rankar's Avatar
rankar
I love this answer,
Eric, how do you know?
CavemanDiesel
Eric Smirh
1985 D90
Originally Posted by Pinballking2 View Post
Thanks All
Any info?
Thanks again
Andy in New York
The leaking seals don't cause the death wobble, but it could tell you that the old bits need to be replaced, I think it means that you should replace all the seals and any moving parts . The parts are not to expensive. You don't want to have steering problems, they are not to difficult to do.
------ Follow up post added September 16th, 2014 05:52 PM ------
Well you asked, I adjusted the pre tension on the swivel pins and did not replace the seals, (after people told me to) Now I have grease all over one of my boost. I can hardly sleep at night,
Old September 16th, 2014, 07:26 PM
Pinballking2
Andrew O'Rourke
1997 Defender NAS
Well, checked he tire pressure and had 40psi in drivers and 30 odd psi in passenger, so reset to 28 on both up front and 35 in rears.
Tires in front are balanced
Problem still exists?
Back to the plan
Preload then bushings?
And CV's on front axle
Andy
Old September 16th, 2014, 07:32 PM
Is your steering box centered? Does your truck feel more vague steering left than right?
Old September 16th, 2014, 08:18 PM
Pinballking2
Andrew O'Rourke
1997 Defender NAS
No but, I experience the wobble at low speed, when the truck hit a rut or pothole, which there are Many in the New York roadways. Point is it happens at very low speeds and doesn't take a big bump to get the wheels swaying?
I did have the whole drag link and ball joint replaced?
Could it have been installed wrong? As in out of center?
Andy
Old September 16th, 2014, 10:25 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Well, checked he tire pressure and had 40psi in drivers and 30 odd psi in passenger, so reset to 28 on both up front and 35 in rears. Tires in front are balanced Problem still exists? Back to the plan Preload then bushings? And CV's on front axle Andy
I was about to do my tie rod ends to try to get rid of death wobble at 45 mph but decided to check tires first. Had similar pressure differences so corrected and rotated the tires and it went away completely. One of the tires that was on the front has about 12 weights on it, so I'm sure it probably needs to be rebalanced. It just makes less impact on the back. Still could be any of the other things mentioned but might be worth rotating tires to see.
Old September 17th, 2014, 07:24 AM
rebuild the swivels and report back
Front End Shimmy loykd Defender Technical Discussions 27 April 11th, 2006 11:08 PM
Front End Shimmy bbandit Defender Technical Discussions 19 April 11th, 2006 11:06 PM
The shakes..while driving.. arbik Defender Technical Discussions 4 December 7th, 2005 12:08 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Front End Wobble RyanS Defender Technical Discussions 7 April 13th, 2004 05:21 PM
