My Flexalite 210 install - Defender Source
Old April 19th, 2005, 11:27 PM
I couldn't see how to attach pics to a PM to Mike H., so I thought I'd post them here. My flex-a-lite 210 install..
charles
ID:	3018   Click image for larger version
ID:	3020   Click image for larger version
Old April 20th, 2005, 06:45 AM
Nice job! Looks much better then mine. You did say something about wiring have you see this?
http://www.defendersource.com/forum/...achmentid=2701
I made it a little while ago to help out with wiring details.
Old April 20th, 2005, 07:08 AM
Thanks Mike! Last night I had dug up
http://www.defendersource.com/forum/...achmentid=1600
from
http://www.defendersource.com/forum/...4&page=2&pp=15
But it did leave a few questions. This one is much clearer, thanks!
Wanna throw me a bone and suggest where to add a thermostat switch in this?
Now if only I had thought to do this before putting my dash back in and closing up the firewall
charles
P.S. I have plenty of aluminum angle left over if you need it
Old April 20th, 2005, 07:19 AM
LOL thats Ok I can get it real cheap up here (read FREE )
So you want to use their T-stat thingy, I used it for a month or so, then the wires started breasking off of the unit, and I realy didn't like how the thermo wire had to go in through the uper radiator hose either. So I took it out and wired it up like I have in the diagram.
But if you want to use it I would bolt it behind the drivers side headlight so the thermo thingy can reach the upper radiator hose. I can re do the wiring diagram so that it fits in their also if ya want.
Old April 20th, 2005, 07:28 AM
No, I want to replace my A/C thermostat with the VW fan switch (Beck/Arnley 201-0809) if I can get it today.
thanks
charles
Old April 20th, 2005, 08:58 AM
Ahh, I shell modify the diagram with that
New Diagram!
Old April 20th, 2005, 10:12 AM
Charles, very nice install. Anybody out there wire their fans up this way on a 97 with A/C? This is going to be my next project.
Old April 20th, 2005, 10:20 AM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I did with AC a year ago. Works just fine.
Doug W.
Old April 20th, 2005, 10:40 AM
Thanks Mike
But doesn't this mean that I can't force the fans on if the thermostat says the engine is cool?
Ideally I am looking to be able to override it - both stop it running and force it to run, and well as let it run automatically by temperature for normal use. Maybe I'm asking to much, or there is no need? Still too knee deep in work to think about this...
charles
Old April 20th, 2005, 10:49 AM
Easy enough, you just need a 2 pole switch. Wire the midle pole to 12 volts and the other 2 go to either the T-stat or the relays
Old April 20th, 2005, 11:03 AM
Doug W.
Did you hook up the thermostat thru the upper hose?
Old April 20th, 2005, 11:08 AM
Cool (and even makes sense )
So middle would be off, one side would be on/auto and the other on/forced right?
I'm getting excited just thinking about tearing apart my truck again!
Gonna ask for VDOs for my birthday
charles
p.s. You know your going to have to add this stuff to the mods section of the site don't you?
Old April 20th, 2005, 12:00 PM
You are right on about the switch. And allot of stuff needs to be added to the custom mods section or the FAQ, we just need to get all moved over to the new server and stuff and get all are ducks in a row to make it work.
Old April 20th, 2005, 12:08 PM
Doug's Avatar
Doug
Doug Walker
Dave, yes, the temp bulb is tucked into the upper hose at the radiator. Comes on at about 175 degrees. I also wired in a three position switch -- always on, always off, or regulated by the thermostat.
Doug W.
Old April 20th, 2005, 12:11 PM
Yeah, I'm throwing a few extra beers in the cooler so we can chat with Chris about it this weekend. Any preference? I owe you a case of the good stuff
Hoping to make time for the wiring this afternoon. need to at least get it running and put a few miles on here before the drive to Rausch.
charles
Old April 20th, 2005, 12:29 PM
I don't drink , but I still want to chat
Old April 25th, 2005, 01:15 PM
Just wanted to close out this thread with a couple points that might not be obvious to everyone.
In Mike's diagrams, the 15A fuses he shows are connected to power at all times. You need to wire these to something that provides soem serious juice, like the the main fuse bus under the hood, or to the alternater.
The switches can be wired to either be powered all the time, or only when the ignition is on. I chose to only have them powered when the ignition is on so that I can leave them in the switched/on position and never have to worry about forgetting to turn them on.
The only change I plan to make to mine is to get a 3 pole switch and change the "off" postion to actually light an idiot light in the dash, so when I do turn them off for a water crossing, i have a reminder to turn them back on again.
charles
Old April 27th, 2005, 11:11 AM
Is everybody pulling out the radiator for the install or has anybody used those zip thingies that go thru the radiator?
Old April 27th, 2005, 11:22 AM
Neither
You can do the install without removing the radiator, and not using the plastic ties.
Put a piece of 2x4 under the bottom tabs of the radiator and bend/beat them flat. Then rivet a piece of 1x1 aluminum angle to the bottom. Use a 2x2 aluminum angle to make the top mount.
hth
charles
Old April 27th, 2005, 11:28 AM
Cool......Thanks!
flex
Flexalite 210 Fan Setup with Mounting Bracket TDI Guy For Sale - Parts 8 December 4th, 2008 08:00 PM
4.6 install will it work ron Defender Technical Discussions 16 February 7th, 2008 10:16 AM
'97 D90 radio install help Defender50th Defender Technical Discussions 0 October 18th, 2005 03:19 PM
Bench seat install in '97 hartop timcd90 Defender Technical Discussions 1 February 15th, 2005 01:57 PM
