my 2.8 TGV drama - Defender Source
Old March 31st, 2016, 02:26 PM
my 2.8 TGV drama
So my engine has been fully dissambled and I have a cylinder out of round due to a disintegrated #3 bearing. I am trying to source the correct cylinder liner to repair it and get my project back on track. Does anybody have any idea who/what/where the liner can be sourced? MWM is no help here.
Mark Kellgren
KM4BOR
Old March 31st, 2016, 02:54 PM
If it is not a bored out 300TDI liner, I would guess you are SOL. Have you tried M&D Engineering?
Old March 31st, 2016, 03:04 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
Try calling Turner Engineering in the UK. They might be able to help. Just checked their website and they do 2.8 type performance cyl heads for about 500 GBP. Not bad. They sell liners but I don't see 2.8 type listed. But they at least might be able to source one for you.
yep. I meant M&D is no help
Mark Kellgren
KM4BOR
Old March 31st, 2016, 03:05 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
WWBD(what would briggs do?)
time to go LS!
Rent my
Old March 31st, 2016, 03:13 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I remember back when I was looking at these motors, there was some dealer down in Brazil that stocked a bunch of parts for them. I can't remember the details but it might be worth searching for.
Man, what a bummer.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old March 31st, 2016, 03:21 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Couldn't you use a universal liner (Melling etc) and have it finish-bored to the correct original dimension?
http://www.mellingcylindersleeves.co...er_catalog.pdf
JL
Old March 31st, 2016, 03:28 PM
you might have this already - but incase anyone else needs them
http://lrch.nl/sites/default/files/I...0Catalogue.pdf
and workshop manual
http://landrover.narod.ru/DEFENDER/T...hop_Manual.pdf
i didn't see liners listed in the parts list - only the piston Ring kits.
from page 69 of the workshop manual
PISTONS AND CONNECTING
RODS
Removal
1. Remove cylinder head.
2. Remove oil pan, suction and lubricant oil flux
pipes.
3. Position the block in the horizontal position.
4. Before removing piston, remove carbon
deposits accumulated on liner top.
Horizontally position cylinders and cylinder
piston to be cleaned at BDC. Fill with a cloth
the space above of the top of the piston.
Remove carbon with a brush or sandpaper
and clean the area with a cloth.
4. Remove pistons.
Disassembly
1. Remove the piston rings.
------ Follow up post added March 31st, 2016 12:34 PM ------
Also... MWM Spare parts dealers in the USA
not sure if they can help...
Company:Teneagri International, LLC Email:sales@teneagri.com Address:14272 SW 140TH ST. Unit 110 Phone:1 786 2709899 Options for action:Genuine Parts Distributor
Company:Daytona Marine Propulsion (Sword Marine) Email:todd.hammons@swordmarine.com Address:1815 N US Highway 1 - ZC: 32174 Phone:1 386 676 7685 Options for action:Genuine Parts Distributor
95' D90 - daily driver..
Old March 31st, 2016, 03:37 PM
this might be an option. I'll explore it. thank you
Mark Kellgren
KM4BOR
Old March 31st, 2016, 03:44 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Very common repair for diesels. Find a good machine shop that is familiar with heavy duty equipment. I have had all kinds of blocks fixed that way. Easy peasy repair for a competent automotive machinist.
JL
Old March 31st, 2016, 04:03 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Jim Pendleton has worked on these engines as well. He rebuilt mine after it completely self destructed after 11k miles.
It made me regret converting from V8 to diesel.
Black Rhino Lives Matter
Old March 31st, 2016, 04:23 PM
Pendy did my original install.
Mark Kellgren
KM4BOR
Old April 1st, 2016, 10:01 AM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
Mark,
Very sorry to hear about the troubles.
It might not help at this point, but I have ordered 2.8 parts from International in Brazil and had very good service, however it was a while ago. I went to the International Brazil site and contacted them, then was put in touch with a very nice group that helped me get the parts needed. That being said, I do not recall cylinder liners, but that does not mean they do not have them.
Personally, the Melling idea seems appealing in terms of time and cost . . .
__________________________________________________
shoefnik wrote: "Itís funny how that moral line you draw for modifying your Rover changes as your needs change."
Old April 1st, 2016, 10:08 AM
Thanks. Plan A was to go with the oversized pistons, but M&D wants $500+ for each one, and you have to do all 4. Ridiculous.
Mark Kellgren
KM4BOR
Old April 1st, 2016, 10:27 AM
A friend had custom pistons made at some place int the States. IIRC, it was a lot less than that and they claim they can do anything. You just send them a current piston and tell them the size you want.
I think it was at Wiseco, Wiseco Manufactures High Performance Forged Pistons & Performance Parts for Motorcycles, ATVs, Snowmobiles, Marine, and Automobiles
Old April 1st, 2016, 12:45 PM
Can you get oversized pistons directly through International?
My first thought would be to get an aftermarket liner machined to the size you need. I'm sure an engine builder could at least point you in the right direction if you aren't sure where to get them.
Old April 1st, 2016, 12:50 PM
Thanks. Not only have I found some part leads that speak english in Brazil, but looks like johan on this forum has come through for me with reasonably priced oversized pistons. looking good for me!
I also found through a friend in guatemala an aftermarket supplier for sleeves, but oversized pistons is plan A at this point. Thanks everyone!
Mark Kellgren
KM4BOR
Old April 1st, 2016, 01:02 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Buddy, this has been a challenge! But I think your truck is in good hands!
Old April 4th, 2016, 02:21 PM
ersatzknarf
Frank
'96 hybrid
Very glad to hear that things are looking up ! ! !
Old April 4th, 2016, 02:35 PM
How much are pistons???
These are set of 8 prices.
http://www.summitracing.com/search/p...-based-engines
-Jeff
I'm getting a set of 4 correct oversized 2.8 genuine pistons from member johan (2.8 parts supplier) for $200+ shipping. I didn't price pistons, but probably get around same pricing from Calpen in Brazil.
My M&D ankle chain has been cut. I feel like Django Unchained.
Mark Kellgren
KM4BOR
Overdrive for 110 with 2.8 TGV Santiago Defender Technical Discussions 96 March 6th, 2011 09:36 PM
Air filter for 2.8 HS TGV engine Santiago Defender Technical Discussions 10 September 20th, 2008 02:24 AM
HS 2.8L TGV 110 Project dannykim8379 For Sale - Vehicles 39 January 9th, 2008 11:43 PM
The 2.8 TGV and 300TDI to GM adapters are in stock OBW_Canada The Vendors Loft 5 December 14th, 2006 11:12 PM
Priced Reduced! - HS 2.8L TGV 110 Project dannykkim For Sale - Vehicles 0 February 17th, 2005 04:01 PM
