Must replace R380 Fork - Do the clutch & rear seal too? - Defender Source
Old May 25th, 2012, 03:33 PM
Landspeed's Avatar
Landspeed
Langdon Hill
D-90 SW
D-90 300 Tdi, 167K Miles R380's fork failed. My Clutch has 50% remaining. With all the work it took to remove the transmission to replace the fork, my thought is replace the clutch and the main rear seal. Anyone else experience this choice? I figure I have 5 more years on the clutch. There is a very small amount of oil on the wrong side of the rear engine seal. Not sure where it came from. I don't want to do this again. So it seems to me the extra coin now will be smarter than having to remove the R380 a second time - even if the clutch has time left.
1. Was it possible to replace the fork without removing the transmission?
2. Is there a better replacement fork. Why would a fork fail? Seems odd to have that be a weak link.
3. OEM clutch fine? This is a daily driver - farm truck and not a rock crawler application.
4. OEM rear main seal - is this the best option.
A mechanic friend told me - not sure if this is true - That the rear main seals are better than replacements - so a small leak in the original is better than a replacement that will leak more and wear out faster.
I tried to find this answer but did not find it, so if there is a link to this please let me know. Thanks.
Old May 25th, 2012, 04:27 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by Landspeed View Post
....... Is there a better replacement fork. Why would a fork fail? Seems odd to have that be a weak link.
See towards the bottom:
http://forums.lr4x4.com/index.php?showtopic=5010
MUDSUX
Old May 25th, 2012, 04:33 PM
No. Engine or gearbox out.
Get an OEM fork (not an aftermarket one) and weld on a backing plate, being careful not to overheat the pivot area. Grease well.
Sure. I'd replace it...
You want one of these: http://www.turnerengineering.co.uk/a.../info-832.html
Old May 25th, 2012, 04:36 PM
Also replace the throwout bearing, slipper pads, slave cylinder and flex line while there.... You can get an alumumium housed throwout if you want even more feelings of happiness.
ac, clutch, r380
off-set clutch in 300tdi match up to r380 kim Defender Technical Discussions 10 April 8th, 2012 03:12 PM
WANTED: Clutch for '94 D90 with R380 jijalicious Wanted 4 December 21st, 2011 10:50 PM
Now stocking 300TDI HD clutch fork brn24whl The Vendors Loft 3 August 10th, 2011 05:57 PM
