multiple batteries issue.. - Defender Source
Old May 13th, 2009, 08:27 PM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
I'm going with a dual battery system to keep my winch happy... I currently have a Warn multiple battery isolator, but wanted something a little more robust with a few more options... I've seen some units (dualmate) that can combine the batteries to assist starting to manually disconnect the two batteries, and a bunch more options...
Can anyone recommend a setup that works well.?
Also, I wanted to go with Optima batteries (one red for start, one yellow for winch, lights, etc..)... any suggestions for what size to use that both can fit in the battery box? I am running a Warn 9.5ti.
Thanks!
Don
Old May 13th, 2009, 10:36 PM
I have the Wrangler Northwest system in my SW and in my YukonXL. I have the red for starting and the yellow for the accessories/winch. It will allow you to charge both batteries at the same time, use them both for starting or turn off the second battery. They have a dual battery holder that is excellent too.
Old May 14th, 2009, 08:11 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I've got the painless wiring dual batter set up. It uses a three position switch. One is both batteries connected and charging,spare batter disconnected, and both batteries connected with the second battery not being charged.Works pretty well. I currently isolate the second battery when the rover sits for longer than a week since I have a drain somewhere in the truck.
Jimmy Buffett
Old May 14th, 2009, 08:29 AM
btate
Bryan Tate
d90
I also have the painless, like Tyler...if I leave the truck not on a battery tender for a few weeks the truck is dead (think its the Sirius radio).
I flip a switch and it starts right up. By the time I'm at my destination the battery has charged.
Very nice to have, vs lifting the seat out and jumping.
Old May 14th, 2009, 10:26 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Not that great for the life of the battery you keep draining though...
~Scott T.
'95 D-90 ST - AA Yellow
Old May 14th, 2009, 12:23 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Recently fitted a National Luna system to Trey Ruewer's D90 with 2 yellows in custom underfender mounts. The original battery box now contains amplifier, crossovers, the National Luna controller, circuit breakers, fuses and a subwoofer.
ID:	19511   Click image for larger version
Email is
Same place, new dogs.
Old May 15th, 2009, 08:17 AM
flippedrover
Tyler
'94 D-90
True but its a marine deep cycle so eh.
Jimmy Buffett
Old May 15th, 2009, 08:26 AM
Treuwer's Avatar
Treuwer
Trae Reuwer
94 D90
Got damn it trevor, I give you enough of my checks- at least get the spelling right.
Old May 15th, 2009, 08:57 AM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Got damn it trevor - you do good work.
Old May 15th, 2009, 01:12 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Old May 15th, 2009, 01:23 PM
I thing the Hellroaring isolator is the nicest.
I cheaped out and did a little different wiring with a normal isolator to get it to work well. http://members.shaw.ca/red90/isolator.html It has been working fine.
Old May 16th, 2009, 10:21 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
I have National Luna setup with dual Odyssey and could not be happier.
See my build thread for pics.
Pat
Kirk Lazarus, Tropic Thunder
Old May 16th, 2009, 02:52 PM
TND90's Avatar
TND90
Keith Allen
94 d90 ST
x2 for the painless. Works great for day to day stuff and when off roading. Everything fit nicely in my box with no mods.
Name:	iphone pics 5-09 073.JPG
"There is no normal life Wyatt, there's just life."
Doc Holliday
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Article from the September 2004 Issue of LRE norros Misc. Chit-Chat 8 September 16th, 2004 02:13 PM
Batteries dead jorge Defender Technical Discussions 13 October 28th, 2003 03:28 PM
