Multimeter type gadget suggestions - Defender Source
Old November 25th, 2006, 10:31 AM
cpk
Corey K-nig
1993 NAS Defender 110
I'm looking for suggestions on a multimeter to use to diagnose sensor and electrical issues. One that is user friendly, I don't know to much about these things. I thought there maybe one out there that is for the Auto tech field or even one for Rover field. I'm not looking for something from like Snap-on that rolls out on wheels, but something more pocketbook friendly. If you have a gadget like this or similar that is immpossible to live without please let me know. Thankstype gadget
Old November 27th, 2006, 11:23 AM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Hey there Corey. Regarding your question on a multimeter, it really is going to depend on what you need it for. First off, I am a longtime fan of the Fluke series. THey are nearly indestructable and in my opinion, the best on the market. I have used a Wavetek that was very close in capability, but considerably cheaper. If you are t/sing sensors, you would need voltage and resistance capability. If you are not familiar with using a meter, you probably don't need to mess with Current capability or readings. Many fo the sensors will change resistance as they measure whatever they are supposed to measure. Voltage is pretty standard, and very helpful. These suggestions are all for DVM or multimeters, not for something liek a code scanner. Unless you have a 96 or newer vehcile, a standard OBD-II scanner is not going to work, unless it is one that offers older vehcile hook-ups like an AutoX-ray 5000 or 6000. Even then, I don't think it will work on your L/R. They do have a nifty digital fault display usually near the ECU, I know mine is. I can elaborate more if you need more info, but e-mail me and I will reply. Hope this helps a little.
Pain is weakness leaving the body
Old November 27th, 2006, 11:33 AM
$10 at wal-mart for the little lightweight multi-meter.
Ron
Old November 27th, 2006, 09:57 PM
robisonservice
John Robison
2008 Supercharged Range Rover
The most useful electronic tester for your '93 would be a Fluke digital meter. www.grainger.com has a full selection. Look at Fluke online, too, and they are also on ebay
Old November 27th, 2006, 11:33 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I like the Fluke stuff, too...it is about the best stuff going...but a lot of money to sink if you use it infrequently. If you have the money & want the good stuff, a Fluke 87 is a good bet. For something a bit less expensive for infrequent DIY, try Sears, they have some Craftsman meters that are a pretty good value for the money ($50 ish) and will do everything you need.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old November 28th, 2006, 12:34 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have a digital POS from Harbor Freight ($1.99) on sale in each of my trucks. I have a couple nice flukes and such at home. I HIGHLY recommend the harbor freight yellow digital pieces of crap for the truck and it will do everything you want it to with the exception of sounding a tone on the resistance loop. Here is the one on sale for $2.99. Still a great buy. Sometimes it drops lower, but you would have to be a serious tightwad to wait. When I saw them last, I bought 10 and gave them to all my friends. 1 did not work, we took it back and they gave a new one, no questions asked.
http://www.harborfreight.com/cpi/cta...emnumber=90899
Old November 28th, 2006, 12:47 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I second the harbor frieght meter. It gets used more then my Fluke, Vantage or Craftsman meters. Cuz I do not mind draging it out in the gravel or overloading the amp draw circuit. A smart test light like Teslite.com would be a good way to dabble in the eleckticky, also.
JP
legend in my own mind
Looking for Front Seat Suggestions smenzel Defender Technical Discussions 39 February 26th, 2006 07:55 PM
no spark suggestions? mattdh Defender Technical Discussions 12 April 25th, 2005 09:59 PM
Suggestions from you gadget people... dmarchand Misc. Chit-Chat 45 May 3rd, 2004 01:38 PM
Recommendation on a Fire Extinguisher - size, type, mounting, etc. COSteve Defender Technical Discussions 16 April 16th, 2004 02:21 AM
Lube Suggestions TDI Guy Misc. Chit-Chat 7 January 19th, 2004 07:56 AM
