Muffler Flange Bolt removal - Defender Source
Old May 28th, 2009, 06:00 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I am in the middle of replacing my exhaust system from behind the catalytic converter. The flange bolts that connect to the muffler are completely rusted. One snapped while I was removing the muffler, and the other is looking pretty tired.
My question is . . . are the flange bolts the type that are "pressed" in, or are they just stuck in there due to rust?
I am pretty sure they are the press in type, so then my next question is should I just drill the old bolts out or try to pound them out? Keep in mind the flange is still attached to the Y pipe which is still attached to the truck.
Thanks in advance for the help.
Greg
Old May 28th, 2009, 06:02 PM
They are press on. On my lwb, I just welded on ground down bolts to the flange after cleaning it up. My D90 would have gotton a new Y-pipe.
Old May 28th, 2009, 06:43 PM
I heated it with a torch and hammered it out.
Crankshaft Pulley bolt removal kellymoe Defender Technical Discussions 16 November 1st, 2006 03:29 PM
Diff Flange Removal HELP! ronward Defender Technical Discussions 2 August 26th, 2006 04:22 PM
Flowmaster Muffler w/about 12K miles 1of40 For Sale - Parts 0 October 3rd, 2005 03:55 PM
Stock Muffler ? FlowMaster ? Others ? norros Defender Technical Discussions 24 June 2nd, 2004 10:56 PM
» Defender Registry
Barbara
curry
Bella
D110DC
Add your Defender
