Mudflaps+Borla - Page 2 - Defender Source
Old February 23rd, 2004, 11:19 AM
shitty. I think my dad was wanting to look at your SW to see if they would work since you have the BOrla and i want to get one if it wont interfere with the mudflap. Do you still have the borla on your SW?
Old February 23rd, 2004, 02:01 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Well, yes and no. It had the Borla exhaust. The Borla muffler sounded like shite so I had a nice glass pack put on. Baffles came loose and it sounded like shite. So the other day, I had a 40 series Flowmaster installed. Sounds much better. I do still have the tip. Phillip, if it is the tip you really like, there is an aftermarket tip that looks exactly like the Borla one. I will try and find out who makes it. I wouldn't spend the money on the whole exauhst. Spend a $120 and get a flowmaster and the tip installed.
Old May 10th, 2012, 04:26 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Resurrecting a very old post for anyone searching the Borla/mudflap combo.
I added genuine brackets and Allmakes mudflaps as the genuine pre-2007 are NLA (no TD5 cut out on the LH side) and I have a Borla exhaust already installed. My first short drive and the LH flap was very hot and a bubble was forming from delamination of the flap. There would seem to be enough clearance between the exhaust tip and the mudflap, but apparently not.
I'll likely have the exhaust tip moved to exit behind the wheel as I like the look and function of the mudflap and it's state law to have the top half of the rear tires covered. I had a friend pulled over for it before and I don't like being pulled over.
Old May 10th, 2012, 05:20 PM
What about a heat shield? You could probably have one not look dumb.
Old May 10th, 2012, 05:43 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
That's not a bad idea. It could bolt to the mudflap mounting bracket. I definitely like how the Borla exhaust is tucked up tight. Would aluminum be best for that?
Old May 10th, 2012, 10:31 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Heat shield installed. .025 gauge aluminum.
Before:
After:
Before:
After:
Aluminum doesn't seem to get too hot and mudflap stays cool.
I just threw it together in about 30 minutes. Works for now and I can improve on it later if I decide to go this route for good.
borla, flaps, mud
Borla Exhaust NEW, IN ORIGINAL UNOPENED BOX! hank17 For Sale - Parts 14 April 17th, 2005 07:28 PM
Borla tailpipe rover4x4 Wanted 24 October 14th, 2004 01:59 PM
Mounting Mudflaps Nobrega Defender Technical Discussions 13 August 20th, 2004 11:19 AM
New Borla Exhaust CATBACK willtillery For Sale - Parts 0 December 6th, 2003 10:04 PM
Anyone have a Borla Exhaust on a 97 hard top? P1CR Defender Technical Discussions 1 October 7th, 2003 12:21 PM
