Mud UK vs Iron Goat Dash Console - Page 3 - Defender Source
Old October 2nd, 2012, 12:44 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
I like the fact that it matches the rest of the switches. The down side is that I am running it upside down. The lighting is fixed so it doesnít light up through the lens. It lights the switch instead. No big deal but annoying. All the rest of my switches are configurable so I was able to wire them up to light up properly.
Wiring it was simple. I made an adaptor harness that plugs into the original hazard switch plug. So no wires cut on the truck. I used crimp on 0.093" Pins that I opened out slightly and they fit in there fine.
ID:	58373   Click image for larger version
Old October 2nd, 2012, 12:51 PM
Thanks! That's what I was thinking of doing too (not the upside down part). I didn't realize until my month in Botswana how important it is to have the hazard in a convenient location and easy to find, when traveling in the 3rd world. Has topped my priority list.
Mark Kellgren
KM4BOR
Old October 2nd, 2012, 12:56 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
The problem with running them the 'right' way up is that the light bleeds out from behind the covers and lights up the front of the panel. It's annoying as it hits that ridge and is really obvious. The way I have it now the whole switch rocker lights up and glows and then flashes when its on. It makes it easier to find which as you say is key when you want to find it in a hurry.
Old October 2nd, 2012, 01:16 PM
interesting. Ill have to play with it and see what can be worked out
Mark Kellgren
KM4BOR
Old October 2nd, 2012, 01:24 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
You can see it a bit in the pic above with it lit up. The 'yellow' light on the front of the console above the switches. That pic was taken during the day, it's much worse and more noticeable at night. It's inherent to the carling switch design not specifically the hazard switch.
Old October 2nd, 2012, 01:27 PM
yep. i have carlings on mine now, but where you have your gauges on top.
Mark Kellgren
KM4BOR
Old October 2nd, 2012, 01:31 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
OK, gotcha. Its a tight fit back there with both...
Old October 2nd, 2012, 01:57 PM
Mine
Mark Kellgren
KM4BOR
Old October 2nd, 2012, 02:03 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Sweet!! That's what I mean by the Mud version offering a better blank canvas that lets you do what you want more readily than the IG.
If I remember right the IG only allows you to fit up to 6 switches across whereas the Mud fits 7 as well?
Old October 2nd, 2012, 02:08 PM
that switch bank on mine came with my original IG! you can see there's some room to spare.
Mark Kellgren
KM4BOR
Old October 2nd, 2012, 02:14 PM
Originally Posted by Overlander View Post
Mine
Vacuum gauge on a diesel?
Old October 2nd, 2012, 02:20 PM
No, if you are looking at the pod on top, its EGT and boost
Mark Kellgren
KM4BOR
Old October 5th, 2012, 01:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks for all the Mud UK console pics. They are making my decision difficult now! Might still go the Iron Goat as I really like the metal inners. I've been driving without the radio on for the past month so not sure if I need or want to spend on a "media center" (although man, some of those setups look nice).
Any Iron Goat owners want to weigh in?
Old October 5th, 2012, 01:42 PM
Grover's Avatar
Grover
Does the IG and Mud UK require dash cutting?
Old October 5th, 2012, 01:45 PM
IG yes, Mud no (unless you want to install any long stuff on the bottom of the console.)
Mark Kellgren
KM4BOR
Old October 6th, 2012, 10:28 AM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
mine
Old October 6th, 2012, 02:24 PM
very nice!
Mark Kellgren
KM4BOR
Old November 10th, 2012, 01:18 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Does anyone with a 97 have either of these consoles installed... I am wondering if they will clear my air con switches?
Old November 10th, 2012, 01:26 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Mark. If you switch dashes I would be interested in your factory 97 switches. Dan
Old November 10th, 2012, 01:28 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I need to something... Too many switches and not enough places to put them lol...
console, dash, mud
mud uk center console - no cut tomaco1 Defender Technical Discussions 2 May 30th, 2011 05:27 PM
WTB: Mud UK Dash Console sonoronos For Sale - Parts 4 May 25th, 2011 01:38 AM
MUD UK Dash steinhnj For Sale - Parts 2 May 4th, 2011 09:08 PM
Iron goat dash console mightymg Wanted 2 November 3rd, 2010 01:47 PM
Iron Goat Defender Dash Kit - Brand new nickt For Sale - Parts 5 June 28th, 2010 06:21 AM
