MTD75D tranny oil - Defender Source
Old September 25th, 2010, 12:49 AM
DieselDef
Brad Ingalls
1985 Defender
MTD75D tranny oil
I'm slowly going through my new to me 90 and replacing all the fluids and things that commonly break down with age. As is often recommended I am putting all synthetic oils in it in hopes that it will increase longevity. i want this thing to last.
Soooo, after doing a little research I read the advise that MTF75D oil is better for the LT77 than the DIII ATF. The thought of running ATF in a manual transmission was a shocker for me that I'm just not comfortable with so the MTF idea is attractive. But before I use it I thought I'd try to find out if anybody here has experience with it.
Has anybody here used the MTF75D, and what kind of difference has it made? Who supplies it in the states? Need some advise please guys.
Old September 25th, 2010, 01:09 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've been running Redline MTL in my R380's for 5 years or so. I get it at a speed shop in Atl. http://www.redlineoil.com/dealers.aspx
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 25th, 2010, 09:38 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
not to hijack but- does anybody have any experience with pennzoil synchromesh fluid in the R380?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old September 25th, 2010, 09:43 AM
I haven't tried it. Had good results with the redline MTL, you can get it for $10/quart at the sunoco on the 5000 block or so of Lee Hwy in arlington.
Old September 26th, 2010, 01:53 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Ditto for Redline MTL...my truck had a really hard shift between 3rd and 4th (has an LT77) but with a fluid change to the Redline all is well. Ordered mine from an online speed shop for about $10/quart
Old September 27th, 2010, 12:18 AM
DieselDef
Brad Ingalls
1985 Defender
Mt75d
Thanks for the input guys. I read a comment on another forum that the Redline thinned out too much in hot weather in that guy's opinion. I guess from your comments that you've no similar complaint. What weight is the Redline? Does it at least stay thicker than ATF?
Brad
tranny quit on me need to source problem, fix quickly myself airbornrover Defender Technical Discussions 0 January 6th, 2009 04:36 PM
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
