Msd Ignition - Defender Source
Old March 5th, 2007, 08:39 PM
Backstay
John Hilton
1994 D90
Msd Ignition
Has anyone actually installed an MSD distributor on a '94? I am looking to do so but need to know the wiring to get a signal for the computer. Thanks, John
Figured it out. Thanks.
Old March 6th, 2007, 10:48 AM
robisonservice
John Robison
2008 Supercharged Range Rover
If you look at your coil you will see a wire that goes from one of the coil terminals up into the wire harness that serves the air flow meter. That's the wire for the engine ecu. It needs to stay.
The other wires on the coil are power and the wire to the ignition amp. That's what you replace with your new setup.
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
Ignition Power bjenk Defender Technical Discussions 9 November 22nd, 2004 07:20 PM
Parking/dash lights - on with ignition in "run" position.. jaherring Defender Technical Discussions 1 September 14th, 2004 07:53 PM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
» Defender Registry
Lloyd
rtcgb
Vader
cwilder
Add your Defender
