mpg - Defender Source
Old April 1st, 2011, 01:18 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
mpg
just calculated my mileage yesterday and found out I get around 8.5 mpg on my 1997 D90 ST. Only has about 70,000 mi on it and a new 4.6 block and a/c so thats a negative. Was wondering if this is about normal for Defenders or if I can get a little better mileage? 10 mpg at least would be nice.
Old April 1st, 2011, 01:25 PM
specops1526's Avatar
specops1526
Beluga '97 90
I get like 10 in mine and probably 9-11/city in both my Discos which have 4.6s.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old April 1st, 2011, 01:29 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
holy crap!!
buy stock in opec and just have some fun I guess
Old April 1st, 2011, 01:33 PM
grnrvrs's Avatar
grnrvrs
Paul
88
~22 around town and 27 on the highway in my 4bd1T powered 110. It's not quick off the line though.
Old April 1st, 2011, 01:34 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I routinely see 14-15mpg in my '94 with a 3.9L
Old April 1st, 2011, 01:35 PM
Any check engine lights?
How are your O2 sensors? Are they original?
It would probably be worth replacing the front two O2 sensors with new as you should be getting at least 11-12.
Ron
Old April 1st, 2011, 01:53 PM
17 in the Loob with a tail wind.
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
These threads always get me wondering. I've gotten 18mpg in my '94 with street tires. I've checked it and rechecked it via GPS and everything I can think of. It was real.
I can pull 16mpg with LTB's.
You guys must have heavy feet.
(and no april fool )
Old April 1st, 2011, 01:54 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
This thread makes me feel a little better about my MPG in the 130. After fueling up yesterday I averaged 11mpg, not bad.
Old April 1st, 2011, 02:12 PM
I get 12-13 doing 90mph.
Old April 1st, 2011, 03:05 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I was averaging 11-12 in my 110 with a very tired 3.9.
Old April 1st, 2011, 03:13 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I assumed it was understood but often forget that folks outside of NOVA haven't seen me drive...my 14-15 is highway speeds well above the posted limits! If I drive "nice" that can go up to 16mpg pretty easy
Old April 1st, 2011, 03:34 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Are you guys calculating your MPG based of odo reading or actual distance travelled? Tire size differences?
You little rebel, I like you.
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
I thought about replacing my oxygen sensors whichare original but the dealer told me they only replace them when they go bad in which case I would have a code. Plus doing all the sensors looks like at least a $400 job and I don't know if it's really worth it to replace them all unless I get about 5 miles to the gallon better than I do now. If replacing the front two will get me 11-12 mpg then I guess that's okay so maybe I'll look into that. No check engine lights. Original wheels and bfg all terrain tires.
Old April 1st, 2011, 03:40 PM
Two things:
1. When O2s throw a code they have to be REALLY BAD. What happens is over time they get slow and MPG suffers.
2. Only replace the front two as the rear two only "check" the front two and don't effect the mixture. Save the front two for it you get a code for one of the rear two. Two OEM new ones from roverguy are $200-250 last I checked.
No promises, but it sounds like something is not right unless you are running on like 36in swampers or something and the O2s are the most likely fault. Do you see lots of black soot in the tailpipe or when accelerating? Does it smell like gas from the tailpipe? Do the plugs look like they are running rich (black sooty build up)?
Old April 1st, 2011, 04:57 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
8.5 MPG holy S*!t on my 3.5ltr running 235x85x16 i got 17MPG around town & 21mpg on a run at 60ish
I now get 24-26mpg on a 300tdi with zfhp22 over the same journey.
It may be worth seeing if you can get the ECU tweeked after the sensors have been proved.
regards all
Gren
Old April 1st, 2011, 05:11 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
That's about what I see too.
Old April 1st, 2011, 06:23 PM
8-13 on my classic, I hold it to the floor everywhere I go it wont die. before I fucked with the top end I used to average 15ish. I am around 10-15 in my 90 with 255's. I used to easily get 17 when my Defender was stock.
Old April 1st, 2011, 09:03 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Weird. I regularly get 14-15 in my 93 110 with a new 4.6.
Chance
Old April 1st, 2011, 10:41 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
http://cgi.ebay.com/ebaymotors/Land-...item33634a3359
47 MPG in a D90 Uncle Douglas Misc. Chit-Chat 20 August 17th, 2008 01:35 PM
"Tornado" mpg saver?! HP increase!? 97Ariesblu Defender Technical Discussions 30 March 13th, 2008 12:51 PM
LR3-Any Feedback? saber6 Misc. Chit-Chat 14 June 30th, 2007 03:27 PM
declining MPG on 300tdi tmore Defender Technical Discussions 5 January 23rd, 2007 09:25 AM
Acetone and fuel MPG kellymoe Defender Technical Discussions 60 November 28th, 2006 01:23 PM
