Moving brake calipers - Defender Source
Old May 1st, 2010, 10:11 AM
Grover's Avatar
Grover
Question Moving brake calipers
Question:
I'm installing new pads and rotors on all corners. How would you guys suggest on moving the calipers out of the way? The front brakelines are attached to a bracket on top of the swivel housing. Would you remove the two bolts from the bracket - or - disconnect the hardline from the caliper? Also, what about the rears? Is there enough flex in the brakeline to move the rear calipers out of the way? I'd like to avoid cracking open any lines...
Cheers...
BTW...I did read Bill Burkes article on the front brakelines, i.e. cutting a slot in the braket to move the brakeline for future repairs. Good idea, however to make the slot, the flexline must be removed.
Old May 1st, 2010, 10:31 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have a piece of 10 gauge copper (since it is stiff and easily bent), a coat hanger or a big zip tie and, when I remove the caliper, I hang it off the spring above the mount. I don't disconnect my lines. I do this carefully, of course, with as minimal flexing as possible and I have never had an issue.
Old May 1st, 2010, 10:56 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
From what I've seen the most suggested method is slotting the bracket so you can pull it out the top any time you need to.
Old May 1st, 2010, 01:09 PM
Grover's Avatar
Grover
Question
Thanks guys. Sorry, don't mean to beat a dead horse but...
What about the front? Do you just remove the two bolts holding the bracket (circled in red)? These bolts fasten the top swivel pin in place. The manual states to disconnect the lines
Cheers...
Old May 1st, 2010, 08:59 PM
jack SF
jack baran
95 ST yellow
DAVIS way is easiest.
Old May 2nd, 2010, 06:52 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have done the removal of the 2 bolts before. Works fine. The only trick is to put a jack under the swivel so that when you remove the bolts, the assembly does not drop down and put pressure on the swivel seal and ruin it.
Its simple. Remove the 17mm bolts, then hange the caliper out of the way with the coat hanger or wire.
------ Follow up post added May 2nd, 2010 06:53 AM ------
in the rear there is enough play in the hard line to just move it up a bit by uncliping the hard lines from the axle tube..
Legend in My Own Mind.
Old May 2nd, 2010, 10:10 AM
Grover's Avatar
Grover
Thumbs up
TDI Guy,
Thanks. Good idea using the jack. That was my plan; it's good to know it's been done before with success. I'll just re-install the two bolts to the swivel pin housing immediately after the caliper is secure and out of the way to avoid any droopng...wish me luck...
Cheers...
brake, vin
Rear brake calipers staying engaged. FlaD90 Defender Technical Discussions 4 April 12th, 2009 07:29 PM
110 front brake pads old/new calipers? Rod Hayward Defender Technical Discussions 2 November 30th, 2007 03:25 PM
For Sale - Brake Calipers And Pistons HUMMER80401 For Sale - Parts 6 May 20th, 2006 11:46 AM
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Front Brake Calipers 1of40 Defender Technical Discussions 7 December 30th, 2003 12:46 PM
