Move parking brake handle to other side? - Defender Source
Old May 7th, 2009, 08:42 PM
Abrooks's Avatar
Abrooks
Tony Brooks
In order to get the D2 cable to work on my RHD (and RH parking brake handled) truck, I can either extend the parking brake cable or shift the handle to the left side of the seat box. It doesn't appear that it's any more than 3 holes in the seat box to shift the brake handle, and one cable clamp from extending the cable back over the xfer case to the right hand side.
Thoughts/opinions? Neither solution is perfect, but both should work.
Old May 7th, 2009, 10:21 PM
This is ideal because it won't hit your leg. I keep meaning to do this to mine.
Ron
Old May 8th, 2009, 12:45 PM
cabell's Avatar
cabell
Cabell Crowther
I moved mine to the left side when I converted to LHD (it was a bit of a reach for me to leave on the right). I bought a LHD handle from Stephen Peters and modified it to work with the early style cable. The new handles come with a switch for the binnacle warning lamp which is a handy item to have. Most of the early trucks I have seen do not have the switch. BTW, the LHD cable is longer than the RHD unit.
Old May 9th, 2009, 07:54 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Was there any difference in the handles other than the warning light?
Old May 31st, 2009, 11:39 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Looks as though there is -- the brackets appear to be mirror images from one side to the other and are not interchangeable. The good news is that it appears that the D2 cable will *just* work on a LHD defender w/o clocking the parking brake assembly.
brake
Parking Brake Abrooks Defender Technical Discussions 15 September 23rd, 2011 09:57 PM
Parking brake problem, handle popping back UP. Hans Defender Technical Discussions 14 January 19th, 2010 02:34 PM
LHD Parking brake handle & Bracket Abrooks Wanted 6 June 4th, 2009 09:29 AM
parking brake switch Campbell Defender Technical Discussions 6 September 20th, 2005 08:45 PM
Parking brake light howellm70 Defender Technical Discussions 4 September 27th, 2004 02:19 PM
