Mounting lights - Defender Source
Old November 29th, 2013, 12:47 PM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
Mounting lights
Hello, I have been trying to mount 7" lights to the bumper but the wiring confuses me. I thought about wiring it to the rear foglight switch because that already has power going to it and I do not want to deal with the headache of wiring to the battery (which is inside the vehicle). Unfortunately I cannot find the wire that goes to the light or where to connect them. In short, I have no idea what I am doing. Please help. Pictures would be nice too. Thanks
Old November 29th, 2013, 01:27 PM
No wiring harness?
Fog lights or driving/spot lights?
Old November 29th, 2013, 01:40 PM
This has future electrical issues written all over it. Pay somebody to do it right if you don't have the skill set to do it yourself. You are going to burn up wiring, melt fuses or melt your fog light switch if you just wire them into the rear fog lights.
If you were in the PHX area I would wire it up correctly (hot from the battery and use a proper sized relay & wiring) for you in my driveway. Perhaps a local to you Defender Source member could help you out.
Old November 29th, 2013, 02:34 PM
87 D110 (Ruby)
Go on fleabay and buy a wiring harness plenty of dummy proof (just a saying ) ones out there - just match to the wattage of the new lights.
Old November 29th, 2013, 03:46 PM
Landyman1's Avatar
Landyman1
Landyman
This is what came with it
Old November 29th, 2013, 04:08 PM
I'm seeing everything you need to install them correctly. Did it come with any instructions?
Old November 29th, 2013, 05:12 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Putting some lights on a vehicle is really just a gateway....
Rent my
Old November 29th, 2013, 05:18 PM
Lesson one: Drill monting holes in bumper and bolt in lights.
Old November 29th, 2013, 05:45 PM
BlackField's Avatar
BlackField
Oscar
D110
Step two: bring it to the local stereo install place and save yourself the aggravation and no offense, avoid a bad installation.
Old November 30th, 2013, 02:18 AM
Landyman1's Avatar
Landyman1
Landyman
not really, tomorrow i am going to have to buy a longer harness because tge power wire is not long enough to reach the battery. Does anybody have any pictures of where they fastened the wires?
Old November 30th, 2013, 08:15 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
This is just basic stuff, Landyman.
If a wire is not long enough, add more wire.
Just start at the beginning.
JMO, if you're going to drive a 35 year old truck, you'll have to learn some of this stuff.
Do not take it to a shop to install the lights for you unless you don't have the time or interest.
In my past experience, the guys who have a shop put everything on their vehicle understand very little about how it works when it breaks down.
And it will break down.
http://www.youtube.com/results?searc...+a+truck&sm=12
Rent my
Old November 30th, 2013, 08:25 AM
87 D110 (Ruby)
C'mon - this is really simple. Yes you have everything you need! Like Jeff said if it isn't long enough - and most will not be just splice in (using crimp connectors/solder and then heat shrink tube) the correct gauge wire. You can get the correct gauge from HD or Autozone etc...
Wiring is easy - like water flow....the switch just interrupts the flow - power can not get to the lights without first going to the switch. Power can not get to the switch without first going to the relay. The switch and the relay must both be grounded.
Red = Power
Black - ground/negative
White is the interrupted circuit - or switch
OH...one more thing - those lights are cheapo shite...you will want to upgrade to better lights in the future - remember the old axiom - You get what you pay for.
Old November 30th, 2013, 09:45 AM
You can also grab power from the starter. In fact you will probably have to shorten the wire if you do that.
Old November 30th, 2013, 09:49 AM
87 D110 (Ruby)
go ahead and run the bare wires in black flex conduit - you can buy 20ft rolls of that at HD and or Autozone too.
You should run it in the flex conduit to protect it, then zip tie it, to keep it nice and stable so it doesn't flap around in the engine bay. Needless to say keep the conduit away from moving parts - and heat producing parts/pipes etc.
Old November 30th, 2013, 10:10 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
I'd highly recommend replacing all the wiring with marine grade (ancor brand wiring?). As well as using a fused relay like this http://www.thesamba.com/vw/forum/viewtopic.php?t=175724
Old December 1st, 2013, 12:34 AM
Landyman1's Avatar
Landyman1
Landyman
C'mon - this is really simple. Yes you have everything you need! Like Jeff said if it isn't long enough - and most will not be just splice in (using crimp connectors/solder and then heat shrink tube) the correct gauge wire. You can get the correct gauge from HD or Autozone etc... Wiring is easy - like water flow....the switch just interrupts the flow - power can not get to the lights without first going to the switch. Power can not get to the switch without first going to the relay. The switch and the relay must both be grounded. Red = Power Black - ground/negative White is the interrupted circuit - or switch OH...one more thing - those lights are cheapo shite...you will want to upgrade to better lights in the future - remember the old axiom - You get what you pay for.
what lights would you recommend?
Old December 1st, 2013, 01:10 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Hella= good lights
Rent my
Old December 1st, 2013, 08:06 AM
87 D110 (Ruby)
Well....I am partial to the Terrafirma 8" HID now that I have them...they make it look like daylight! And HID are far superior IMO
Something simple: Hella, like Jeff said are good, PIAA are also good - but I think Lightforce are better
So good, good, better - best...there you go
Old December 1st, 2013, 08:22 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
One could also use the alternator for a power source. Fused, feeding a relay- I use the waterproof hella 40 amp relays, overkill for the amperage, but once and done right?- and there are plenty of ground points under the hood. I also use shakeproof washers to ensure a good connection for the ground.
Email is
Same place, new dogs.
Old December 1st, 2013, 04:17 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Oh boy.
Like Dave said, just throwing these lights in as you have them now is just asking for trouble.
A bit of learning is in order.
First, the fuses:
Any time you run power from a source to an accessory, you need a fuse "inline" on your positive wire. This is to keep everything downstream (i.e., the lights, and the wire running to them) from setting your truck on fire if there is a short somewhere. If the lights short out and start drawing massive current (basically acting like an arc welder), your fuse will burn up and cut the power to the short. You can do inline fuses (they look like this), but try to avoid that. The reason you don't want to do an inline fuse on your wire is that you will eventually end up with fuses all over the place and it will be hard to track down the problem when something burns out.
A better solution for power distribution is to use a centrally-mounted fuse box:
A fuse panel (like the Blue Sea Systems model shown above) is an easy and clean way to centralize all of your accessory wiring. You run power and ground directly from the battery to the panel and then run all of your accessories from there. The battery box underneath the drivers seat is the perfect place to mount a fuse panel. For your lighting installation, you'll use a relay (more on that later) and run power from the fuse panel to the relay and then on to your lights.
Now, relays.
It's a really bad idea to hook high-powered accessories up directly to a switch. That sends a lot of current through the switch and you're risking it burning up and failing over time. Instead, you want to use the switch to switch a small amount of current to your relay, which is designed to switch the big current that the lights need. The relay has a small electromagnet (the "coil") that does the switching. There are always two connectors on the relay for the coil; one goes to your dashboard switch and the other goes to ground (do it nicely and ground your relay to the ground terminals on your fuse box). The relay also has a "common" connector, which is where the big current from your power source (ideally, your fuse panel) is attached. Finally, there are two output connectors on the relay: one called "N/O" for "normally open" and one called "N/C" "normally closed". The "N/O" is only powered when the coil is energized (i.e., your dashboard switch is on), so that's the one that you will want to connect directly to your lights. That's usually labeled "87" on most 12V automotive relays. The N/C output is not used for this application so you can leave that unwired.
Here's a wiring diagram to help you out:
Also, it is a good idea to solder a diode across the the coil terminals of your relay. A diode is just a one-way gate for electricity. The diode will keep electricity from the coil from flowing back to your dashboard switch, which could potentially burn out your switch over time. Solder the diode from 86 to 85, with the white stripe on the 85 side. Just like this:
Finally, the wiring.
It's pretty simple:
- Use good wire. Marine grade (like Ancor) is best.
- Buy a wire crimper and use the right crimp for your connector.
- Use good connectors. A long time ago, someone on this board taught me about heat shrink connectors and they are awesome. You crimp them like normal connectors and then heat them up to seal the connection. Here's a great place to buy them.
- Use the proper connectors for the your terminals and wire. Terminals and wire come in all variety of sizes and you want to pick the right style of connector for what you have. The Blue Sea fuse block, for example, uses #8-32 terminal screws so if you had some 14ga wire, you would buy these ring terminals to attach your wire.
- Sleeve your wire in some kind of wiring loom. As others have mentioned, you can get that black PVC stuff from Autozone. Personally, I like to use expandable braid sleeving. It's tough as nails and super easy to use. You can even buy high-temp versions for running wire near hot spots.
- Use grommets any time you run wire through a hole. This is super important and will help keep you from burning your truck up.
- Spend the time to properly route your wires. Alongside existing wiring and through existing holes is best, but make sure your wires are sleeved. Avoid hot areas like the exhaust and areas that might be exposed to road debris or lots of water.
- Use the right gauge wire for the job. Heavier gauge wire is more expensive and more difficult to run but it loses less power (i.e., your lights may shine brighter) and it's safer. Use this chart and the specs on your lights to find the correct wire gauge:
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Mounting Lights to the Bar michael15 Defender Technical Discussions 3 February 9th, 2006 08:49 PM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
flickering lights nykx Defender Technical Discussions 1 November 12th, 2004 06:10 PM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
