Mounting Hella FF1000s to the stock bumper bar. - Defender Source
Old April 3rd, 2011, 08:49 PM
FortyTwo's Avatar
FortyTwo
1997 Defender 90 SW
So, I thought I'd switch out some Hella Comet 550s that were on my truck to a newish set of FF1000s I had in the garage, but ran into problems. The bolt that fits into the bar from the Comets is smaller that the FF 1000s, so they'll not fit in the same location out of the box. The larger FF1000 bolt is the type with a square head to prevent rotation in a plastic bracket on the light. Not sure if I'll be able to find a replacement with a smaller thread.
Checking in to see how anyone has overcome this already, instead of trying to reinvent things. Suggestions?
Old April 3rd, 2011, 10:17 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
I have 1000 FF Hella. I had them on my Toyota before and the bolts corroded. Need to cut them in order to retrieve the spots. After that I used normal 6 pans bolt to secure them on my 110 bull bar. I used a normal wrench as there's only enough space to use the spanner on the bolt between the spot and the bracket.. No easy nor amusing task but I haven't found any replacement square headed bolt so far...
Old April 4th, 2011, 03:11 AM
TS888's Avatar
TS888
Tony Sims
1984 110
If you need a square headed bolt look for battery clamp bolts. You can probably find them on that rack of "Help!" parts at most chain auto parts stores.
Alternately, a bit of time with a carriage bolt and a file would result in square heads.
Tony
1984 110 "Smokey" (sold)
bumper, mount
Mounting Lights to the Bar michael15 Defender Technical Discussions 3 February 9th, 2006 08:49 PM
Stock Radio, Brush Bar, Running Boards, etc... Kneel For Sale - Parts 13 August 6th, 2005 08:51 AM
Aux Light Mounting Bar mod4b Wanted 9 July 18th, 2005 01:48 PM
97 brush guard and bumper (stock) Seriesman For Sale - Parts 1 November 1st, 2004 01:10 AM
Mounting Hella 4000s with Stock Bumper/Brush Guard jbird Defender Technical Discussions 5 June 10th, 2004 06:01 PM
